I have an inspection in the next few days for a realtor who is buying the house. Just met her last week.
She tells me it has hot water radiant heat. I don't run into these systems very often and I THINK I forget what to look for, aside from leaks. Any suggestions? </IMG> Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
Ian Gills is a non-member guest and is in no way affiliated with InterNACHI or its members.
If this is central heating, which we have in the UK and is far better than the blowing air solutions you use in the US, piping hot water on a closed system to white radiators from a gas-fuelled boiler then you could consider the following:
Check each radiator can be turned on and off. They may need bleeding. Check the thermostat works (sometimes these are attached to each radiator) Drain a pint of water from the system as a sample and check the colour.
Lime scale builds up on the inside of the boiler's heat exchanger which reduces the boilers efficiency and can cause the boiler to make a banging noise. Check the pressure in the system. Should be about 0.7 - 1.5 bar. Too much pressure can put a strain on the pump. Too little, I am not sure what happens but most systems close down and it could be evidence of a leak. Actually, just looked it up and it might be underfloor heating you want. So please disregard. Sorry. I guess radiators are a bit too advanced for the US (as is putting power cables under the ground to greatly reduce the incidence of weather-related outages)! Underfloor heating. Ouch, that's gonna be expensive. Last edited by Ian Gills; 2/21/07 at 2:45 PM.. |
Thanks for your thoughts Ian.
She says it is an older home so I think it may be radiators like you have in the UK, not the newer underfloor systems like in America. BTW Whitby Ontario is in Canada Cheers Off to the pub I go! </IMG></IMG></IMG> Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
And life would be so much easier if wires were joined with these http://img.alibaba.com/photo/5114694...inal_Block.jpg rather than these http://www.inspect-ny.com/aluminum/ja-8.jpg I'll stop now. Armored cable IS a good idea. It's seen as too expensive in most countries. Am I off-topic? Last edited by Ian Gills; 2/21/07 at 3:58 PM.. |
ekartal6 is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would also look for any signs of moisture damage under the shut off valves which often leak.
Thanks Erol
I was more interested in things at the boiler. pressure guage? check valve? that kind of thing, signs of impending doom/failure? etc. Cheers </IMG></IMG> Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
</IMG></IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
A water leak visible at the time of inspection is an obvious no-brainer. The damage to a floor from previous leaks over a long period of time may not be. Some of those old wood floors are as soft as a sponge under the valve. I never said not to inspect the mechanicals.
Thanks for the help guys, as I said in the first post , I don't see these systems very much. I was looking for a refresher
Thanks again Cheers Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
Here's my inspection protocol for the boiler portion of the inspection of hot-water systems, put together from various sources.
I welcome any comments, corrections or suggestions: ----------- Check for Sight glass and/or low water cutoff: If so steam, conversion, or hybrid system. Describe as Open or Closed System: Closed (forced) system will have circulation pump. Observe piping: Closed system with over-sized pipes pitched toward boiler usually means a conversion from older open system, may be missing safety devices. Observe Expansion tank: If open system: 3" above highest point of system and ventedObserve Pressure Relief Valve: 30 psi , piped to w/I 6" of floorObserve High Temp Switch: Hi Limit: Typically 210F. If higher, suggest service. Above 250F is likely safety hazard.Observe Backflow Preventor: Observe location: Should be on cold water supply upstream of pressure regulator.Observe If Pressure Reducing Valve Installed: PRV (AKA auto make up valve or feed water pressure regulator) is not required, it is a convenience. If Closed System: Observe Circulation pumps(s):Observe drain valve: Missing or closed is defect – often modification of older open system Observe Evidence of past/recent repairs. Service tags? Observe Draft Diverter/Hood: Check inside for corrosion, scorching, and back-drafting Observe Piping Material. Observe Piping Type: - Two Pipe (AKA Loop): circa per 1950 large diameter pipes, two runs each with capped end.Observe Piping Insulation: Possible asbestos? Observe Boiler: cast or welded (cast iron will not have welds at pipe connections). Observe at least one cycle: Record: thermostat settings Last edited by mthomas2; 2/22/07 at 10:01 AM.. |
Mike good post
Thanks Mike:
Just what I was looking for. I did forget a few things Cheers </IMG></IMG> Doug Cossar CMI, NHI Accurate Home Inspection Services Inc. Whitby Ontario www.accuratehomeinspections.ca 05021384 |
Very nice Mike, thanks for sharing that
Joe Kormos A-1st Look Home Inspectors Inc. 630-201-0933 Your 1st Choice in Property Inspection Professionals www.a-1stlookhomeinspectors.com www.a-1stlook.com Let us look before you buy...for peace of mind “Thinking is the hardest work there is, that’s why so few engage in it. ” Henry Ford |
| Radiant Heat Transfer | rmyers1 | Structural Inspections | 0 | 5/31/06 11:21 PM |
| Need Help On Chimney Liners | Nick Scibetta | Exterior Inspections | 13 | 1/11/06 9:53 PM |
