Old 11/28/10, 3:11 PM
Douglas Cossar's Avatar
Douglas Cossar Douglas Cossar is offline
Default HRV Installation
What, if anything is wrong with this HRV installation?
Doug Cossar CMI, NHI
Accurate Home Inspection
Services Inc.
Whitby Ontario
www.accuratehomeinspections.ca
05021384
Need a home inspection in Arizona? Check out InterNACHI's listing of Arizona certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 11/28/10, 4:23 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
Default Re: HRV Installation
In order for it to work as a HRV it must be receiving the air from outside not in the location of the same room. This is just going to work as a filter system only.
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 11/28/10, 11:52 PM
Banned
That is an entry level stripped down builder's "appliance"
-Has it been balanced.....Ask for balance report.
-Needs a loop trap on the condensate drain.
-No flex duct anti-vibration collars between hard duct and unit duct collar
-All duct joints should be sealed with foil tape or high velocity duct sealer
-That unit needs to be sloped at least 1/8" to the rear to prevent condensate from running out access door
-Don't see any insulated flex duct running to the exterior.....
-Manufacturer's instruction booklet not in place in plastic clip on upper front right of access door
-depending on the date of manufacture, this unit may be under manufacturer's recall for fire hazard
-This model had a minor interior design flaw that I find in 8-9 out of 10 units- when you open the acess door, you may find a small hanging rod that is unhooked from one of the internal motor driven dampers designed to operate in tandem (they blocak cold air from the exterior when the units is not running and is a "wait state" until a sensor, timer, dehumidistat calls for ventilation.
Any more pictures?
The HRV system may have been set up to distribute fresh air through the larger furnace/HP/AC duct seen above the unit. Although meeting code, it is not the best installation method.....2 separate duct systems are better for both fresh air and heat flow adjustments.
Old 11/29/10, 6:15 AM
Thanks Brian
I don't see these units very often. I did note the fact that there was no insulation on the duct leading outside though.
That's the only picture.
Cheers
Services Inc.
Whitby Ontario
05021384
Old 11/29/10, 8:52 AM
Banned
Thanks Brian
Cheers
Must be a homeowner installation; definitely not by an HRAI (Heating, Refrigeration and Air Conditioning Institute) trained/certifed installer!!
Old 11/29/10, 2:52 PM
David C. Macy's Avatar
I believe this may be the link for the manufacturers instructions.
http://www.indoorairquality.net/Venm...tructoinfo.htm
What model is this one in the picture?
Old 11/29/10, 7:40 PM
Banned
From the above website:
Apparent sensible effectiveness at 0°C (32°F).............81% at 31 l/s (66 cfm)
Apparent sensible effectiveness at -25°C (-13°F) ......80% at 37 l/s (78 cfm)
Notice that the manufacturer has not said efficiency in the above claims but still uses the % symbol.....They all do that in their brochures to mislead the consumer! They do not include true tested efficiency but APPARENT (it looks like) sensible EFFECTIVENESS..(what does this grab-all general term really mean?....effective at what? catching flies in the incomng fresh air??) This practice is included in my 85 item list called "Smoke & Mirrors in the energy field"
Pellet stove help chellickson General Inspection Discussion 23 8/19/10 1:23 AM
Shooting to begin on comprehensive new roofing courses kshepard Inspection Education & Training 4 11/7/09 2:59 PM
Grounded conductors cduphily Electrical Inspections 144 11/16/08 10:28 PM
Bonding wire installation requirements ?? rnewman1 Electrical Inspections 7 7/31/06 2:31 PM
