Old 5/24/06, 12:10 PM
David C. Macy's Avatar
Default Humidifier????
The home is heated by a boiler with baseboard registers. The home is cooled by a York cooling system. My question pertains to the humidifier. I thought they are for forced warm air systems. Why would there be one on just a cooling system. There also is one sitting on the counter.
Thanks
Dave
ID:	3667   humidifier-70606-north-royalton-020-small-.jpg.jpg
ID:	3668   humidifier-70606-north-royalton-019-small-.jpg.jpg
Old 5/24/06, 1:52 PM
tnoisaw tnoisaw is offline
Please Note: tnoisaw is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Humidifier????
You may also be able to use it to add humidity to your home in the winter months. It could also act as a air handler. Check to see if it has settings for air only without AC.
Old 5/24/06, 2:19 PM
Doug Edwards's Avatar
My dear old grandmother always kept a cast iron water kettle on her wood stove in the kitchen and one on the potbelly stove in the living room to keep the home humidity higher in the winter time. It adds to the comfort level and her good wooden furniture would not dry out and split. By keeping the humidity higher in winter the home does not have to be heated nearly so much as the humidity equates to "latent heat". The same reason humidity works against us in summer it works for us in winter. Ive seen where some units are run in "fan" mode only just to circulate and filter the indoor air.
Furnace Problem Comments Welcome rfrost Inspecting HVAC Systems 28 10/21/07 6:26 PM
Steam humidifier? kshepard Inspecting HVAC Systems 2 5/16/07 10:01 PM
Humidifier supplied by hot water dmull1 Plumbing Inspections 5 2/26/07 12:59 PM
HVAC Humidifier sfalvey Inspecting HVAC Systems 6 12/21/06 9:04 PM
Humidifier type? dmacy Inspecting HVAC Systems 1 10/22/06 8:56 AM
