Whole house flow through type humidifier mounted on evaporator coil cabinet wall. I opened the humidifier cover, evaporator coils exposed!
[ATTACH] ![]() [/ATTACH]
| Need a home inspection in Ohio? Check out InterNACHI's listing of Ohio certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Looks like the humidifier screen to me, not the evaporator coil.
Yes, that is an expanded metal element of the humidifier.
I usually see them in the return air side here. Check mfgs. instructions. http://www.aprilairehumidifierparts....product=110713 You can argue with intelligent people but to argue with a mush head is like trying to grab fog-Thomas Sowell |
I've installed similar "By-Pass Type" Humidifiers on the supply plenum in the past. The catacomb ceramic or paper screen filter looks like it's pass due needing to be replaced. It probably could have been cleaned earlier on, but looks like it has passed that stage. Maintenance is critical to efficient, leak proof operation, and if allowed to get to this stage, is a possible algae/mold breeding problem. I recommend having it checked and cleaned by a pro HVAC Contractor.
| Opinion: Smoke Alarm Location | cevans | Interior Inspections | 10 | 6/16/09 6:31 PM |
| Receptacle location, Code In "FLORIDA" | jacaron | Electrical Inspections | 8 | 11/8/08 5:23 PM |
| Stupid Mounting Location | Tab M. Wilcox | Electrical Inspections | 9 | 6/22/08 1:54 AM |
| Humidifier supplied by hot water | dmull1 | Plumbing Inspections | 5 | 2/26/07 12:59 PM |
| A/C location of expansion device vs line temps. | bking | Inspecting HVAC Systems | 9 | 5/29/06 4:16 PM |
