Old 7/20/10, 4:57 PM
Michael J. Merino's Avatar
Michael J. Merino Michael J. Merino is offline
Default Humming AC
Outdoor AC compressor is about 9 years old. I removed the shutoff switch and the fan stopped, but there is a loud hum to the unit. I have read that this is normal for a heat pump, but this is not a heat pump. When I went inside and turned off the thermostat, the humming stopped. Any thoughts?
Michael Merino
Merino's Home Inspection & Education Inc.
"Not just an Inspection, an Education"SM
Phone/Fax 708~535~6057
Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/20/10, 5:03 PM
Chuck Evans's Avatar
Default Re: Humming AC
Probably the the relay contacts which run on the low voltage wire. Sometimes they're noisy.
Chuck Evans (TREC #7657)
Houston Home Inspector
Houston, TX
Old 7/20/10, 5:05 PM
Is this an issue to be referred to an HVAC company, or is it normal operation?
Michael Merino
jmcmahon's Avatar
jmcmahon jmcmahon is offline
Run relay was pulled in by the thermostat.
Jeffery M. McMahon
Williamson, Ga.
Old 7/20/10, 5:51 PM
Should I recommend evaluation/repair by an HVAC company?
Michael Merino
Old 7/20/10, 6:00 PM
A buzzing noise is typical.
Houston, TX
Old 7/20/10, 8:49 PM
It perhaps is typical, but is likely a symptom of rust or other corrosion buildup on the relay armature (not the contact) which keeps it from closing all the way. This reduces the closing force on the contacts and, over time, will lead to contact failure. When I find that type of condition, I recommend addressing the issue at the next annual service visit. By the way, the problem is not limited to heat pumps as the same type of relay is used on A/C compressors as well.
P.S. - should this happen at your own home, the problem can be resolved by lightly sanding the armature mating surfaces or just replacing the relay - they are pretty cheap anyway.
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 7/20/10, 9:22 PM
Larry J. Michael Larry J. Michael is offline
Unusual noise, recommend evaluation by a licensed mechanical contractor.
Greensboro Home Inspection
Providing home inspections in Greensboro, High Point, Burlington and the surrounding areas.
greensboro-home-inspection.html
Raleigh Home Inspection
Home inspections in Raleigh, Durham, Cary, Chapel Hill, Apex and surrounding areas.
Raleigh-home-inspection.html
BassRumors.com
Providing a blog, news, and forum dedicated to bass fishing.
Old 7/20/10, 10:05 PM
Bob Elliott's Avatar
Mike do you always kill the shutoff switch?
How long do you leave it off before returning power?
Old 7/20/10, 10:30 PM
ldapkus ldapkus is offline
Why the hell would you shut it off???
Old 7/20/10, 10:41 PM
Guess you don't check for overheated conductors, line/load or grounding???
Houston, TX
Old 7/20/10, 11:09 PM
I'm not an electrician, just a generalist home inspector.
2.5. Cooling
I. The inspector shall inspect:
A. the central cooling equipment using normal operating controls.
II. The inspector is not required to:
A. determine the uniformity, temperature, flow, balance, distribution, size, capacity, BTU, or supply adequacy of the cooling system.
B. inspect window units, through-wall units, or electronic air filters.
C. operate equipment or systems if exterior temperature is below 60 degrees Fahrenheit, or when other circumstances are not conducive to safe operation, or may damage the equipment.
D. inspect or determine thermostat calibration, cooling anticipation, or automatic setbacks or clocks.
E. examine electrical current, coolant fluids or gases, or coolant leakage.
A. insert any tool, probe or device into the main panelboard, sub-panels, distribution panelboards, or electrical fixtures.
B. operate electrical systems that are shut down.
C. remove panelboard cabinet covers or dead front covers, if they are not readily accessible.
D. operate or reset overcurrent protection devices or overload devices.
E. operate non-accessible smoke detectors.
F. measure or determine the amperage or voltage of the main service equipment, if not visibly labeled.
G. inspect the fire or alarm system and components.
H. inspect the ancillary wiring or remote control devices.
I. activate any electrical systems or branch circuits which are not energized.
J. inspect low-voltage systems, electrical de-icing tapes, swimming pool wiring, or any time-controlled devices.
K. verify the service ground.
L. inspect private or emergency electrical supply sources, including, but not limited to: generators, windmills, photovoltaic solar collectors, or battery or electrical storage facility.
M. inspect spark or lightning arrestors.
N. inspect or test de-icing equipment.
O. conduct voltage drop calculations.
P. determine the accuracy of labeling.
Q. inspect exterior accent lighting.
Old 7/20/10, 11:43 PM
2.5. Cooling
So your answer would be "NO" and your excuse is that it's not specifically spelled out in the SOP. Curiously, I don't even see checking for the presence of a disconnect means in the SOP, aside from the main service disconnect. Does that mean you don't report if there is no disconnect at all for the AC condenser, electric water heater, furnace/air handler?
Please forgive me, as I use the TREC SOP vs. NACHI so I'm not nearly as well versed in all of the things you are NOT required to do.
I do routinely check for the presence of a disconnect. I also check for equipment ground connections, signs of conductor overheating and line/load orientation. With most enclosures that does require pulling the disconnect handle.
Houston, TX
Old 7/21/10, 12:04 AM
I am not sure it is a good idea to be pulling fuses and tripping mains to see if they are functional as part of a Home Inspection and have never seen anyone around here do so.
Texas may be different .
I tend to be with Linus on this ,though not worded as strongly.
Put this in do so at your own risk as much as pulling breakers out of every panel.I simply raise the flap and check for damage if it is running.
Old 7/21/10, 8:39 AM
Same here, I don't pull fuses/breakers. The equipment may not turn back on. What do you do when you shut down an A/C unit on a 90+ degree day and the 90 year old owner is without A/C?? I just dished out $3400 for an A/C unit for my mother-in-law in Florida because she had a $35/visit handyman check it out.
Ladder humming on roof rack sgilligan1 General Inspection Discussion 12 2/5/09 12:47 PM
Transformer humming noise mnicholet Electrical Inspections 13 11/25/08 4:05 PM
Humming Balast rmaday Electrical Inspections 10 3/26/08 6:59 PM
humming thermostat fodette Electrical Inspections 3 2/6/07 6:35 AM
Humming gporter Plumbing Inspections 13 11/25/06 6:31 PM
