Old 4/26/07, 2:54 PM
Carl Durfee Carl Durfee is offline
Default Hvav
Is there a rule of thumb to determine the amount of BTU's a heat pump system equipped with a couple of emergency heating coils should produce? Is the rated amount encoded in the units model #? I have yet to see it spelled out on any mfg. info. tag(s). When I kick in the emergency heat on the thermostat, the electric heating coils each draw around 40 amps., but I don't have any idea how many BTU's are being generated. Thanks in advance for any help.
Old 4/26/07, 3:12 PM
cbellefontaine's Avatar
cbellefontaine cbellefontaine is offline
Send a message via MSN to cbellefontaine
Default Re: Hvav
I'm no expert on electric heating. Usually electric heat is measured in Kilowatts. I think it is somewhere between 3500 and 4000 btu's per Kilowatt. Let me know if the Kilowatt rating is labeled.
Sincerely,
Charles M. Bellefontaine
Bellman Group, Inc.
877-316-0600 Extension #802
Click Here to Join our Email Newsletter
Get Illinois Home Inspector Pre-License Education and
Continuing Education at www.bellmangroup.com
Low cost professional report writing with a contact
management system. www.myreportwriter.com
Old 4/26/07, 4:41 PM
Default Re: Hvav
Charles is correct--electric furnaces don't BTU, they KW.
Old 4/26/07, 4:47 PM
Doug Edwards,  CMI's Avatar
Default Re: Hvav
Amps X Volts = Watts
Watts X 3.413 = BTU/Hr
As a side note; HEAT PUMPS are sized for the Air conditioning load and not the heat load, otherwise the air conditioner will be oversized and that's another whole story.
Old 4/28/07, 6:26 PM
Gary Reecher Gary Reecher is offline
Send a message via Yahoo to Gary Reecher
Please Note: Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Hvav
Just got a Testo 435-2. Has 2 wireless thermometer probes with RH% heads measures airflow and calculates btu's cooling or heating. Busy reading the instruction manual on it. Then a few test runs on my furnace and a/c
Old 4/29/07, 9:54 AM
Default Re: Hvav
I would appreciate it if you would get back to me on whether you like or dislike the new testing equipment you purchased. Thanks, Carl Durfee
