Go Back   InterNACHI Message Board > Specific Inspection Topics > HVAC
HVAC Topics include heating, venting, and air conditioning.
Old 5/5/07, 1:18 AM
Bruce A. King's Avatar
Default Hydronic heat air handler
I came across one of these today, the t-stat had problems so I did not get to do much testing.
Anyone have any experience with these?
It was plumbed to the gas water heater in a small home.
http://www.alpinehomeair.com/related...es%20Specs.pdf
http://www.alpinehomeair.com/related...structions.pdf
www.BAKingHomeInspections.com
704 301-3207
Old 5/5/07, 11:11 AM
Marc D. Shunk's Avatar
Default Re: Hydronic heat air handler
Not much to say about them. They're just a hot water coil, not unlike the radiator in your car, that is inside an air handler (blower). The stat will most often open a zone valve to the coil, and a little pipe mounted thermostat on the outlet of the coil will bring the blower on when the coil has heated a little bit (so you don't blow cold air right away). Connected to a domestic water heater is a tad weird, but that's the way things are done in small dwellings sometimes to save the cost of a proper hot water furnace.
Was this the same water heater that they were using for domestic hot water? If so, I'm not so sure that hydronic coils and zone valves, as well as the circulators typically used, are NSF rated. That would be my personal concern with your particular setup.
efficiency of 15 yr old peerless afrost HVAC 11 11/19/07 10:51 AM
Electric Air Handler - Heat Pumps Scott Schultz HVAC 9 5/24/07 2:55 PM
Condemned Furnaces Spark Safety Issues Gary Reecher HVAC 7 3/8/07 9:17 PM
Radiant Heat Transfer rmyers1 Structural 0 6/1/06 12:21 AM
Ducane Heat pump and air handler dates?? tallen HVAC 16 3/3/06 5:43 PM
Popular
Membership
Education
Chapters & Members
Articles & Links
Other Organizations
