Has anyone ever come across this? At today's inspection I ran the Heat Pump in "heat mode" for about 20 minutes before I noticed ice build-up on the exterior condension unit.
I know this happens in the cooling mode as a result of low refrigerant, but what about in the heating mode? Kevin |
Hi Kevin, heat pumps are not my forte but a google search brought this.
I
Kevin |
Hi Kevin,
That is a fairly high temperature for the outside coil to be freezing up, especially as it was only on for 20 mins, remember as well that the ammount of frosting will also depend on the ammount of humidity in the outside air. The exterior coil in heat mode will always freeze up when run at low temps with high humidity, and is designed to go into defrost mode automatically every hour. That one of yours probably is low on refridgerant, as it is freezing up to fast and at too high a temp I would recommend that the system be serviced BTW for comparison my 4 year old outside coil down here in the humidity capital of the world seldom freezes up unless the outside air temp gets around the low 40's with higher humidity. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
Thanks for all the replies, they were very helpful. NACHI members are the best!!
I think I will spend some time today "brushing up" on Heat Pumps Kevin |
Lets get it right AC systems and Heat pumps just shouldn't work at all based on what most people understand about boiling points and evaporation Quote:
Confused of Clearwater "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
years in a vo tech for HVAC and was unable to wire his first thermostat for a heat pump. He could not do the work so later on they made him a boss???? Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
The other possiblity is that the system had the condensing unit replaced without replacing the evaporator. Mismatched systems is getting to be a problem with companies that want to sell that unit without regards to system operation in both modes. At least when 2010 gets here with R22 phaseout this problem should be reduced.
If anyone is interested I can e-mail a pdf file of a test report that Bristol Compressors made on mismatched systems. Just e-mail me at mechacc at essex1.com subject: Mismatch System If anyone can tell me how to upload a pdf file on this forum I can do that as well. |
| Radiant ceiling heat? | bmargiotti | Inspecting HVAC Systems | 16 | 1/24/12 10:46 AM |
| Radiant Ceiling Heat | hhull | Interior Inspections | 9 | 7/26/07 8:19 AM |
| Heat Pump Inspection | cyezza | Inspecting HVAC Systems | 18 | 1/10/07 9:19 PM |
| Radiant Heat Transfer | rmyers1 | Structural Inspections | 0 | 5/31/06 11:21 PM |
