Does anybody know why ice would be forming on 4 feet of line set near the perimeter wall inside of the crawlspace here in Ohio when the AC [not heat pump]has not been run and it is 20 degrees out ?
Thank you, Darrell's Home Inspections 937-477-6917 |
| Need a home inspection in Illinois? Check out InterNACHI's listing of Illinois certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Could be a split in the line. There is always the possibility that you weren't the first inspector under the crawlspace since the home has been up for sale.
If it was a low spot in the line set and condensation was forming, it could be freezing as it drips dowm the line in that spot. Might be a stuck reversing valve if it is a heat pump system. Just a couple of WAG's without knowing more. Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers |
Gary Reecher is a non-member guest and is in no way affiliated with InterNACHI or its members.
With the extreme prolonged cold temperatures we have been having it could just be outside air. If the house is in negative pressure and the opening for the line set is not adequately sealed cold air can be pulled in and frost form on the line.
"conduction".
| Main Line vs. Supply Line Reporting Details | sshockley | Plumbing Inspections | 2 | 6/14/09 4:07 PM |
| Slope of waste drain line. | mlong | Plumbing Inspections | 5 | 4/23/08 10:54 PM |
| Selected Electrical Incidents and Occurrences - First Quarter | pabernathy | Electrical Inspections | 0 | 12/2/07 2:43 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 8:59 AM |
