Old 5/31/07, 10:56 PM
Jeff Merritt Jeff Merritt is offline
Default Ice on refrigerant lines at compressor.
Had one today warm air at evaporator coil and ice on refrigerant line. I called it out, as no temp differential and the ice. Just wanted to know what could be the cause. dirty a-coil? or improper gas ? too much or too little? not trying.
Old 6/1/07, 1:02 AM
David A. Andersen's Avatar
Default Re: Ice on refrigerant lines at compressor.
Dirty coil, blower or other air flow issue.
Old 6/1/07, 1:04 AM
Charley L. Bottger's Avatar
The two most common causes of frost on the suction line is low air flow across the evap and or low on freon can be a combination of both. an over charge of freon does not cause frost. The suction pressure has to be below 55 PSIG in order to freeze the moisture on the line.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 6/1/07, 1:06 AM
David I thought you were in bed we both posted almost the same time. GOOO to bed I am
NACHI Member
State License # 130
Old 6/1/07, 6:14 PM
Charlie, I took my new camera on inspection today! It was a pre-listing for a former client.
Got some great shots! None of which I will use in their report. Just for me!!
Will post when I get all my stuff out of the truck.
You need one of these things!
Old 6/2/07, 3:52 AM
I am going to have me one soon
NACHI Member
State License # 130
Old 6/9/07, 8:14 PM
John F. Esposito John F. Esposito is offline
What kind of camera are you guys talking about??
I hope yyou don't mind me asking.
Old 6/9/07, 9:22 PM
Don't mind at all its almost in every thread on this BB IR CAMERA.
Therm imaging
</IMG>
NACHI Member
State License # 130
grinding noise on startup Scott Schultz Inspecting HVAC Systems 8 7/13/07 10:09 AM
the 65 degree question cbrands Inspecting HVAC Systems 18 5/1/07 5:01 PM
Refrigerant Lines bking Inspecting HVAC Systems 30 7/17/06 9:51 AM
