This was recently installed in the garage by the home owner (he was an HVAC contractor).
Anyone want to explain what they see as the problem? I'll give you a hint - IRC 309.1.1 IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 2/28/07 at 4:15 PM.. |
Wild,...does he also have a butcher shop in town?
Where is the Zinsco? |
No Zinsco here. This one had a Bull Dog (pushmatic).
Bull Dog....
Man I get a kick out of the things you come across.... What did you recommend for the breach?..... |
It was a long narrative that basically explained what is not allowed with emphasis on the breach of the rated separation. You would think the owner already knew what was wrong, being a contractor R309.1.1 Duct penetration. Ducts in the garage and ducts penetrating the walls or ceilings separating the dwelling from the garage shall be constructed of a minimum No. 26 gage (0.48 mm) sheet steel or other approved material and shall have no openings into the garage. </IMG> IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
cbuell is a non-member guest and is in no way affiliated with InterNACHI or its members.
Jeff,
Does that flex stainless have to be "positively" mounted to the structure where it transitions to the valve and flex connector? |
Yes it does Charles, although that was only a "minor" condition compared to some of the things this guy did.
The long narrative included securing the CSST and several other things. The entire installation was "suspect." Here's another example of this guys handy work. . . IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net Last edited by jpope; 2/28/07 at 4:15 PM.. |
- Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
I didn't see anything like that Mike. The installation was only a couple months old.
I thought that he may have used a torch of some sort to 'fit' these fittings by the scorch mark (if that's what it is) below the connection in the pic...
We used to say "there are two kind of plumbers (gas fittings might apply here), pipe fitters and pipe fighters!" - Mike Michael W. Gault, SC RBI 1728 A to Z Home Inspections Charleston, Dorchester & Berkeley Counties in S.C. NACHI05040682 www.atozinspector.com (843) 442-9755 Charleston Home Inspector |
makes you think twice when you: "Recommend repairs by licensed HVAC contractor."
flex line not allowed to run into the unit casing. I also think that the yellow flex was recalled due to lightning problems causing leaks and fires.
Appliance connectors are not allowed to pass through the cabinet, you are correct.
There have been no recalls on CSST. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Question about improper installation | cbell1 | Exterior Inspections | 3 | 10/24/07 10:13 PM |
| Improper installation | Robert Robson | Inspecting HVAC Systems | 3 | 7/20/07 9:50 PM |
| Bonding wire installation requirements ?? | rnewman1 | Electrical Inspections | 7 | 7/31/06 3:31 PM |
| Window installation | jmichalski | Exterior Inspections | 17 | 1/24/06 10:42 PM |
| Common Installation Deficiencies | jkline | Electrical Inspections | 0 | 1/12/06 9:58 AM |
