Old 7/16/10, 5:14 AM
Joshua L. Frederick Joshua L. Frederick is offline
Default Individual filters in air diffusers
New electric heat pump install. They installed filters in each air diffuser throughout the home. This can't be a good idea, due to having to change each filter and/or remembering to change each one, correct? There was a regular filter as well. Anyone ever seen this? Any helpful insight is always appreciated. Additionally, why does electric breaker to heat pump have to be on a minimum of 24 hrs.?
Thanks in advance.
Need a home inspection in Delaware? Check out InterNACHI's listing of Delaware certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/16/10, 6:29 AM
Bert B. de Haan Bert B. de Haan is offline
Default Re: Individual filters in air diffusers
I have seen the individual filters before. My concern was also that the filters would get forgotten and restrict flow. I also don't see the point to the extra filters. No idea about the breaker.
Benchmark Home Inspection Services.
http://www.KitchenerWaterlooHomeInspector.ca Kitchener-Wateroo and Guelph area Home Inspection
Serving Kitchener-Waterloo, Guelph, Orangeville, Mount Forest and surrounding areas.
Old 7/16/10, 7:41 AM
Wayne B. Wilson's Avatar
The heater is supposed to be on for 24 hours ( if the unit has been long term shut down) right now i would not worry about it. it is to insure all refrigerant is boiled out of the oil.this would not be a problem in the summer time.
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 7/16/10, 7:45 AM
Banned
Even the clean filters restrict airflow, let alone when they get dirty.....Bad idea, they're not necessary. Must be manufactured/sold by someone with little knowledge of the HVAC industry.
In a combustion heating system, I've heard a story of the individual register filters restricting air flow so much that the unit shut down on its "high limit" control.
Old 7/16/10, 1:24 PM
David A. Andersen's Avatar
not only is HVAC air duct designed specifically for performance, the diffusers have specific operating criteria. If you add a filter media below the diffusers you change this design and will affect comfort levels (whether the system was properly engineer or not ).
it is highly unlikely that your system was designed properly to start with, however including this "homeowner fix" only degrades the operation of the system.
BPI# 5015804
Washington State Inspectors - Your Deadline Is Near Mike O'Handley Legislation, Licensing & Legal Issues for Inspectors 54 4/14/10 9:15 PM
NO Filters sdonnelly Inspecting HVAC Systems 7 2/5/10 10:13 PM
Democrats Enacting Gun Control - I Told You So..! jmckenna1 Miscellaneous Discussion for Inspectors 42 2/17/09 1:38 PM
MERV Efficiency Rating for Filters Brian A. MacNeish Inspecting HVAC Systems 21 1/6/09 4:27 PM
