Old 8/22/07, 12:31 PM
Kevin Luce's Avatar
Kevin Luce Kevin Luce is offline
Please Note: Kevin Luce is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Information on failed ductwork in a slab
Does anyone have any good information on failed ductwork in a slab with sand and/or water entering. I did a search on the internet and couldn't find anything.
Old 8/23/07, 12:42 AM
Brian E. Kelly's Avatar
Default Re: Information on failed ductwork in a slab
Sand and water are not supposed to be in HVAC ducts. The ducts in question should be evaluated by an HVAC contractor or a Mechanical contractor.
Old 8/23/07, 10:06 AM
Charley L. Bottger's Avatar
I typically do not get overly concerned with a small amount of sand as this could have entered the system during the construction stage. Depends on the amount.
Water different story when I find water I recommend that the ducts be sealed with concrete and a up-flow system be installed. Proper drainage surrounding the foundation should also be addressed to prevent water from entering under the slab foundation.
I alway recommend that a camera scan be performed to determine the actuaal condition of the embedded duct work.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Moisture in slabs mcyr Structural Inspections 7 8/20/07 7:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 10:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 7:53 PM
below slab ductwork bzybura Inspecting HVAC Systems 1 7/18/06 10:14 PM
