Old 1/26/12, 2:29 PM
Michael Larson's Avatar
Default Infrared Room Heaters
Does anyone have any experience with these?
I would like to hear pros and cons for discussion.
Michael Larson
Hudson, WI
Need a home inspection in Arkansas? Check out InterNACHI's listing of Arkansas certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/26/12, 2:47 PM
Joseph Hagarty,  CMI's Avatar
Default Re: Infrared Room Heaters
https://www.heatsurgehtsale.com/?MID=1374702
Like the Electric Fireplaces built by Amish Craftsman who do not use electricity.?
Joseph P. Hagarty
joseph.hagarty@comcast.net
Main Line Inspections, Inc.
Phone: 610-399-3675
Email: MainLineHI@comcast.net
Old 1/26/12, 2:52 PM
But they do use electricity.
On the high setting, 1500 watts
Oh, you meant the Amish Cabinet builders.
Michael Larson
Hudson, WI
Old 1/26/12, 2:58 PM
KEVIN WOOD's Avatar
KEVIN WOOD KEVIN WOOD is online now
My brother purchased one for his wife. She needed it because of the romote control since she can't walk easily. I wish this company would come up with a remote control.
This is the most efficient heater, I have tested it myself against other brands.
http://www.seabreeze.ca/heaters/Ther...lo_sf12st.html
THE RIGHT TRAK
CIAQP, IAC2
Certified Master Inspector
kwoodinspections@hotmail.com
Cell: 705-971-2096
Ph : 705-946-2676
Old 1/26/12, 3:00 PM
What makes it the "most efficient" ?
Michael Larson
Hudson, WI
Old 1/26/12, 3:09 PM
KEVIN WOOD's Avatar
Read the info and test it. 840 watts on setting.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 1/26/12, 3:12 PM
That does not answer my question.
As these are ALL electric and electric heat is near 100% efficient they should all be very close in efficiency with the only difference being any motor to move the air if so equipped.
Michael Larson
Hudson, WI
Old 1/26/12, 3:21 PM
KEVIN WOOD's Avatar
What costs more to heat a room 1500 watts or 840 watts?
The unit adjusts to a set temperature by your comfort. This is what makes it the most effective at producing true 5120 BTU's/room at less than other units including the Comfort Furnace.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 1/26/12, 3:26 PM
There are 3.414 BTUs per watt KEVIN.
A unit using 1500 watts would run less often than a unit using 840 watts for the same size room so I don't understand your argument.
Michael Larson
Hudson, WI
Old 1/26/12, 3:30 PM
Roy D. Cooke, Sr's Avatar
1,500 hundred watts gives the same heat IR or Resistance .
High price for the same amount of heat .... Roy
One heats the air and the other heats the object .
Old 1/26/12, 3:33 PM
What are you saying Roy.
These are all very similar in the amount of heat(BTUs added to the room) produced whether they cost $29 or $600.
Michael Larson
Hudson, WI
Old 1/26/12, 3:42 PM
KEVIN WOOD's Avatar
I have only one comment to give to both of you.
5120/btu's is not what it produces. It performs the function of.
Yes you are right 3.414/watt so for the same performance you get
2867 watts and this is not on all the time.
You will never have the testing for this unless you do the comparison like I have.
THE RIGHT TRAK
CIAQP, IAC2
Cell: 705-971-2096
Ph : 705-946-2676
Old 1/26/12, 3:44 PM
Jim Mosiuk Jim Mosiuk is offline
We have used one for 3 years in a rear addition on our house room is 16x24. It works great set at medium and heats the room.
Old 1/26/12, 4:05 PM
Yes exactly One looks better But does not do a better job... Roy
Old 1/26/12, 4:11 PM
Oh yes it does KEVIN.
There is no magic here.
The conversion from electrical energy to heat energy is very close to 100% in these heaters.
It is very simple physics.
Nearly all the energy is converted from electrical to heat as there is no light produced and no mechanical energy produced.
Michael Larson
Hudson, WI
Infrared inspection rcooke Thermal Imaging, Infrared Cameras & Energy Audits 5 4/12/08 12:42 PM
Water heaters in attics phughes Plumbing Inspections 1 1/11/07 11:08 AM
