| View Poll Results: Do you open chimney acess doors | |||
| Yes |
32 | 66.67% |
| No |
4 | 8.33% |
| Depends |
12 | 25.00% |
| Voters: 48. You may not vote on this poll | |||
Wanted to ask if other inspectors inspect the access door for chimneys.
For example; You cant look down the stack at the roof do to pitch/cap. I try to open the doors if accesable. I usually find dead birds and I like to use a mirror to see if the flue is clear and if there are any visual defects. Some times the doors are in poor condition & are rarely if ever opened. Thanks Dave |
If I can get to it and open it I look in it. I found one full of water which was strange since it had a rain cap.
kevin Kevin M. Kenny, Sr. Kenny Home Inspections Oak Forest, Illinois 60452 Nachi #6070990 http://kennyhomeinspections.com
jmichalski is a non-member guest and is in no way affiliated with InterNACHI or its members.
I look, but often find that they have not been opened in so long that simple operation is not possible (and I am not about to force it or break it). I will also say very little about it in my report.
Usually, I am referring the chimney out for cleaning or a Level II inspection by a certified chimney sweep anyway, so I include the ash box and access door for evaluation as part of that service. |
Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
President, Great Lakes-East Chapter Join NACHI Great Lakes - East Chapter http://mi.nachi.org/greatlakes-east/about.html ssieg@gfn.org |
I always look if there is one.
I've never heard of a chimney access door and, obviously, never seen one. Can someone post a few pictures; I can't tell what that posted picture is.
RR - it is a cleanout under the "floor" of the chimney for models with ash bins.
If, on the floor of the fireplace, there is a grate or other opening to sweep ashes into, there will be a cleanout somewhere (basement or exterior of home) to allow you to go in and clean out the ashes by the shovel full periodically (or if you are like most homeowners, never!) These are my pics from my home.... |
However, if that what is being called a "chimney access door," then, when possible, I do open them. Rarely do I find one accessible because all of our fireboxes here either are full of logs and ashes (and I don't clean out fireboxes; that's the chimney sweeps' job) or they have installed a gas logset of some type. If I were to call anything the "chimney access door," I would consider the damper to be such. NACHI 2005 U.S. Member of the Year
Perhaps I have the wrong terminology. I have always called the opening on the floor of the firebox and ash door or ash catcher. The other opening I refer to as the chimney cleanout, although I suppose it is more correctly referred to as the ash box cleanout.
Maybe I have been using the wrong terms, but I thought the firebox was the area where the fire exists in the fireplace. The area below that should have another name (but again, not a chimney or fireplace expert - I refer all that stuff). I still knew where he was going with the question....The part he was referring to as the chimney access door is the opening I show on teh exterior of the home below the fireplace level where the ashes collect. |
But since the ash is below the firebox, there would be no access to the chimney through the ash cleanout door (hopefully) other than through the firebox and then through the damper. But I think I'm with everyone now, I hope. So if we're talking about the ash cleanout door on the exterior, yes, I open them (when possible, they usually are rusted shut or been covered up with soil). If we're talking about the ash door in the bottom or side of the firebox, yes, I open them when possible. If we're talking about the chimney damper, yes, I open them. So I guess I could have avoided these few posts by just saying, "Yes," huh? NACHI 2005 U.S. Member of the Year
A quick search found this:
Good to know. |
I open dampers and atempt to open the others, but often have a hard time with the clean out doors.
In the end, they all get referred for a Level II inspection by a chimney sweep, unless they are nice and clean. |
As an example, back in February or so I found a 1984 fireplace that I told my Clients looked like it had never been used, not even once. But I still recommended a Level II inspection, and I'm sure glad I did. They took my advice (love it when Clients do that) and the chimney sweep found all sorts of problems. After getting a report and a "Thank you" from my Clients, I'm now of the opinion that one of two things happened: 1 - the builder or his subcontractors did a sloppy job and no one ever found out 2 - someone did eventually find out but possibly settled with the builder or his subcontractors for money and then spent the money on something else, or those who found out about it didn't have the money to get the necessary repairs done. You just never know. Note that if you go to csia.org, the Level II inspection is recommended whenever real estate changes hands. There is not an exception for chimneys that "are nice and clean." I suspect there's a reason for that. NACHI 2005 U.S. Member of the Year
Good point. I have only had two nice and clean chimneys, and they were in newer construction (less than 2 years old), however - builder error is worth considering.
A toast! |
cmccann is a non-member guest and is in no way affiliated with InterNACHI or its members.
Kevin,
The chimney you looked at..was it used for furnace or water heater drafting? If so water in that area can mean a blocked chimney....bird nest etc... Add some points when the BCS sytem is in place. |
| Newbie here with a slab "standards" question | Robert Young, #3 | Structural Inspections | 17 | 4/10/07 10:48 AM |
| Fireplace Enclosure | jpope | Interior Inspections | 19 | 10/25/06 5:08 PM |
