Old 9/26/07, 7:14 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Default Insufficient Return Air??
Does this install allow sufficient return air? This is the only return on a zoned system with the filter right at the top of the stairwell.
I seem to recall about 180 sq inches needed for a 3 ton unit.
The install itself is ugly... and yes it's New Construction.
insufficient-return-air-2415-thoreau-083.jpg   insufficient-return-air-2415-thoreau-086.jpg   insufficient-return-air-2415-thoreau-085.jpg
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 9/26/07, 7:20 PM
relliott's Avatar
relliott relliott is offline
Please Note: relliott is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: Insufficient Return Air??
That sucks,or should I say it doesn't.
Your right it is not enough.
Got a 7pm and hope it is better than that.
I assume from your comment this is at least a two story job.
Old 9/26/07, 7:24 PM
Marc D. Shunk's Avatar
Banned
The workmanship is poor, at least. Looks like the person doesn't know how to squeegee down their tape, and also looks like they used leftover fire alarm cable for the thermostat wiring.
Old 9/26/07, 8:14 PM
It's a 1700' ft two story home...
- Mike
NACHI05040682
(843) 442-9755
Old 9/26/07, 9:10 PM
Bruce A. King's Avatar
1700sf typically has a 20x25 filter
www.BAKingHomeInspections.com
704 301-3207
Old 9/26/07, 9:14 PM
This one had a 14x30 filter but only a 14x16 hole in the actual wall for the free air which was then reduced to about 13x9 as it runs under the air handler...
- Mike
NACHI05040682
(843) 442-9755
Old 9/26/07, 9:16 PM
I actually think it would have been better to place a louvered door in the room and simple bottom filter installation...
But's that why I'm asking the HVAC gurus out there.... I'm not one, but I play one on TV...
- Mike
NACHI05040682
(843) 442-9755
Old 9/27/07, 12:47 AM
Charley L. Bottger's Avatar
Nope going to be very noisy and almost guaranteed hot spots
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 9/27/07, 1:11 AM
mbarnett mbarnett is offline
Definatly poor workmanship...I would defer to a contractor for further evaluation.
Michael Barnett C.H.I. #NACHI07081803, HIF#9725A
Barnett's Certified Home Inspections BL#10009708
(661) 816-4123
www.barnetts-inspections.com
mbarnett@ca.nachi.org
www.nachi.org
Old 9/27/07, 1:25 AM
Whom do you suppose installed this in the first place me thinks you need to evulate the evaluator.
NACHI Member
State License # 130
Old 9/27/07, 9:54 AM
Is this the only unit for a two story home? Around here, you almost always see two units, even if it is a zoned system. Workmanship, unfortunately, looks a lot like some that was done when my home was built !!
Frank P. Newman
Emerald City Inspections, LLC
Dublin, GA
Old 9/27/07, 12:22 PM
relliott's Avatar
Forbid they use a micro filter.
Old 9/28/07, 8:37 PM
Dan G. Happer Dan G. Happer is offline
Please Note: Dan G. Happer is a non-member guest and is in no way affiliated with InterNACHI or its members.
when sizing duct, most professional HVAC people use the CFM approach which is warrented for each install. i have no idea total length of duct and sizing throughout so I could not say off hand what size return is needed. You really can't judge air flow by duct work. BUT, looking at pics, I can say it is definetly needs to be tidied up and checked by HVAC pros
Dan
Old 9/29/07, 12:28 PM
Banned
Uusally try to design about 400 cfm per ton and return ducts about 20% larger than supply.....so from a local HVAC supplier catalogue "INFO" section:
If all zones were calling for AC together, you would need about 270 sq in for return air.
Return air from crawl space WHI Inspecting HVAC Systems 11 1/9/12 8:43 PM
Critter in the return air duct... swaskewicz Inspecting HVAC Systems 11 11/28/07 4:49 PM
Reduced return air duct mmorgan Inspecting HVAC Systems 4 6/6/07 8:39 PM
strong return? mharrod Inspecting HVAC Systems 14 12/6/06 7:28 PM
