| HVAC Topics include heating, venting, and air conditioning. |
Do you recommend insulating both freon lines on heat pump for when the flow is reversed in heating or cooling mode?
Mark Nicholet Apple Home Inspections LTD My Blog InterNACHI member Infrared-Certified CAHPI(BC) member BC Licence # 47592 Last edited by mnicholet; 10/28/08 at 3:26 PM.. |
Freedom Express Inspections LLC CMOR Thermography Certified Level 11 #2097 freedomexpressinspections.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F Professional Home Inspector State License # 130 Reporting system by Home Inspector Pro Serving the State of Okla. |
It's not Freon, by the way. It's "refrigerant".
Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
Im curious as to why there are two liquid lines? Is there some kind of heat recovery system integrated into the heat pump, perhaps to augment the water heater? But in answer to the original question, no, Ive never seen or heard of anyone doing this either. The vapor line would be absorbing a lot of the heat from the liquid line which you do not want.
Doug Edwards, CMI |
One is the thermostat wire.
As for insulating lines, the liquid line is always the liquid line in a HP. It is never below the dew point so it does not need insulation. The reason for the insulation is to keep it from sweating, it has not real job in the thermal loss aspect. The only time we insulate two lines is in refrigeration. The suction line is connected to the liquid line and is used to cool the liquid line to increase evaporator efficiency under load changes. Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Certified Level II Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
[quote=dedwards;430841]Im curious as to why there are two liquid lines? Is there some kind of heat recovery system integrated into the heat pump, perhaps to augment the water heater? But in answer to the original question, no, Ive never seen or heard of anyone doing this either. The vapor line would be absorbing a lot of the heat from the liquid line which you do not want.[/quote]
Doug only in the cool mode would that occure in the heat mode your large line or the hot gas vapor line would be the hottest of the two lines and you would not want any heat transfer from the large line to the small line as you want to transfer all of the heat possible at the A-coil not in the line set in between the two units. Yes Dave was right there is a thermostat wire in the pic that if one does not look close hard to tell. Mister Funderburk Freon/Refrigerant is splitting hairs yes we know brand names Yes David is right also, the liquid line is always the liquid line or the small line but it reverses flow and the vapor line or big line is always the vapor line either hot or cold but it also reverses flow depending on the Stat mode Freedom Express Inspections LLC CMOR Thermography Certified Level 11 #2097 freedomexpressinspections.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F Professional Home Inspector State License # 130 Reporting system by Home Inspector Pro Serving the State of Okla. |
David,
You are right, one is the thermostat wire and its the biggest one Ive ever seen. Looks just like copper until you look real close and see the swirl from the wire twisted inside the outer casing. Most of the ones I see are so wimpy, and typically dry rotted and hanging on a thread. This one is a lot cleaner install than most I run across. Doug Edwards, CMI |
sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
Looks like someone ran the stat wire inside 3/8" soft copper which I have done several time when the dog chewed the wires.
Of course I could be wrong, I was one time before. |
The liquid line seems to be kinked where it first turns up from the unit. Is this a problem? Would it restrict the flow?
I think they used the insulation as a protectection going through the wall is it insulated under the crawl space also?
I think the kink is just camera perspective. was also looking at that.
A suction line kink is much worse than a liquid line kink. Quote:
| 980 Questions/Answers to the NHIE....Free! | jbushart | Legislation, Licensing & Legal Issues | 50 | 4/20/08 2:26 AM |
| Radiant Ceiling Heat | hhull | Interior | 6 | 7/26/07 9:19 AM |
| Radiant ceiling heat? | bmargiotti | HVAC | 12 | 3/21/07 1:12 PM |
| Heat pump in a 80+ year old masonry house | jskrypka | HVAC | 9 | 11/25/06 11:47 PM |
| Question on my heat pump | dbush | HVAC | 7 | 3/12/06 1:15 AM |
