Rick Vollmer is a non-member guest and is in no way affiliated with InterNACHI or its members.
The plenum for the furance/a.c. is located in a vented crawl space of my home. It is supported by the floor joists. I was able to insulate under the bottome and most of the sides and ends with Reflectix insulation. However due to condensation drain pipe and other running pipes, I cannot get the Reflectix on the top.
My question is: Can I run R-19 insulation into the joists cavitiy (which I will do anyway) but then I'm thinking of running unfaced R-13 under that portion of the joists that can rest tightly on top on the plenum. Will this work or can there be a problem of some sort that I cannot think of? I hope I expained my question so you can understand it. As usual, many thanks for your help |
| Furnace Problem Comments Welcome | rfrost | Inspecting HVAC Systems | 24 | 10/21/07 7:26 PM |
| Sweating decision:Settle for lower SEER to use existing furnace? | Fel Randolph | Inspecting HVAC Systems | 2 | 6/6/07 3:56 PM |
| Armstrong Ultra 80 Oil Forced air furnace | Stephen Frazer | Inspecting HVAC Systems | 19 | 4/9/07 9:00 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 9:17 PM |
