Old 3/26/08, 6:10 PM
Jeffrey S. Campbell's Avatar
Jeffrey S. Campbell Jeffrey S. Campbell is offline
Send a message via AIM to jcampbell Send a message via MSN to jcampbell Send a message via Yahoo to jcampbell
Default insulating a slab with radiant heat
What is the proper method for insulating a concrete slab home with radiant floor heat?
yesterdays inspection has an exposed area of the exterior slab, insulation cut short... and it is melting the snow away from the home... heat loss?
Jeff Campbell
Campbell Property Inspections
http://www.maineshomeinspector.com
Pittston, Maine
NACHI04013010
Old 3/26/08, 11:11 PM
Banned
Default Re: insulating a slab with radiant heat
Is that 1" of foam insulation showing above grade? I hope that its not the slab protruding out from under the siding.
Old 3/26/08, 11:12 PM
2" rigid foam insulation that is not flush with the top of the slab... i will try to post another angle...
Jeff Campbell
Pittston, Maine
NACHI04013010
Old 3/26/08, 11:15 PM
here is a different angle... and yes... no support for the door sill
Jeff Campbell
Pittston, Maine
NACHI04013010
Moisture in slabs mcyr Structural Inspections 7 8/20/07 8:33 PM
bbbb mcyr Structural Inspections 1 8/19/07 11:26 PM
Moisture control for slab on grade in protecting floor finishes mcyr General Inspection Discussion 2 8/13/07 8:53 PM
Radiant Ceiling Heat hhull Interior Inspections 6 7/26/07 9:19 AM
Radiant Heat Transfer rmyers1 Structural Inspections 0 6/1/06 12:21 AM
