Skip Erwin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Not sure if this is the right forum. But, I thought you guys would know the answer. I ran across this today in a crawlspace. It's a foil with a paper backing. It's stapled to the floor joists.
Is it considered insulation? If not, what's it for? Thanks in advance. |
Vapor barrier.
Scott Schultz is a non-member guest and is in no way affiliated with InterNACHI or its members.
In addition to being a vapor barrier it is also a radiant heat barrier which can be thought of as insulation in that it will reduce heat loss/gain.
Hot summers and mild winters here. It's very rare to see a vapor barrier installed like this here. This is a one in two hundred install!
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 6:45 PM |
| Vaulted Ceiling Insulation | rcooke | Canadian Inspectors | 4 | 1/22/07 12:24 PM |
| New Old Insulation | rcooke | Canadian Inspectors | 1 | 12/13/06 5:25 PM |
| Crawlspace Insulation | gbrasseur | Structural Inspections | 12 | 12/3/06 3:18 PM |
| WH blanket | badair | Plumbing Inspections | 5 | 7/2/06 7:10 AM |
