Old 3/18/08, 4:52 PM
lolsen lolsen is offline
Question Insulation around the chimney
Doing a Thermal Scan last night and walked by the furnace and got a question in my head. Is the insulation allowed to be stuffed all around the chimney???
Your thoughts. 3 year old house
Thanks
Lawrence
Old 3/18/08, 6:13 PM
Default Re: Insulation around the chimney
Hey Lawerence;
Vertical Checklist
Although the part numbers vary from manufacturer to manufacturer the components stay the same. Reference the list below to ensure you have the correct pieces for your installation.
Thru-Ceiling Installation
Component Where used Notes
Ceiling Adapter First Room Adapter for ceiling support box
Ceiling Support Passing thru 1st Ceiling
Box
Passing thru 1st Ceiling Requires an adapter to connect
Attic Shield
Passing thru attic space
Required to give insulation clearance
Firestop
Passing thru 2nd floor
Adds clearance/stability
Roof Flashing
Above the Roof
Seals homefrom moisture
Storm Collar
above the Roof,on flashing
Seals flashing form moisture
Roof Brace
Above the Roof
Adds horizontal support
Vertical Cap
Last Piece
Stops sparks/flash from igniting roof
Optional
Elbow Strap
In any offset
Used to support pipe between elbows
Elbow
Bypassing offsets
Use incombinations with rigid pipe
Adj. Roof Support
used in Cathedral Ceilings
provides support when transitioning
*Remember to also check your owners’ manual and the vent pipe manufacturers’ instructions for specific part numbers.
Horizontal Checklist
Thru-Wall Installation
Component
Where used
Notes
Stove Adapter
On appliace flue collar
Used to connect pipe to appliance
Wall Thimble
Passing thru a wall
Provides mandatory clearance to joists
Tee Support Bracket
Outside of wall
Prodives vertical support
Tee
outsie of wall
Horizontal to Vertical transition and provides external cleaning access.
Optional
Elbow Strap
In any offset
Elbow
Bypassing offsets
Adj. Roof Support
Provides support when transitioning
Horizontal Cap
Outside Wall - Termination
Pellet Vent/Direct-Vent Only
Hope this helps
Marel
Old 3/18/08, 6:17 PM
Jeffrey R. Pope's Avatar
The short answer would be no. It's not okay.
Jeff Pope
JPI Home Inspection Service
Santa Clarita CA
(661) 212-0738
Santa Clarita Home Inspection
http://www.MyInspector.net
Old 3/18/08, 6:24 PM
Hey Jeff;
I think that what I said didn't I. ha. ha.
Marcel
Old 3/18/08, 6:30 PM
Sorry;
I forgot to talk about the PVC pipe and the brutal obstruction of that poor 2"x4". ha. ha.
But that would be page two.
Marcel
Old 3/18/08, 6:43 PM
Thanks for the info. Just what I thought. So how does this get missed with the city inspectors? This is just beside the door going into the furnace room. So close it jumped out at me.
A good reason to get another inspection done.
Thanks
Lawrence
Old 3/18/08, 6:46 PM
Just talked with a wood stove installer about another issue and he said there is an insulation out that is approved to wrap the chimney in these cases. He did not know if it was approved for gas but did not see why not. Wood gets hotter than gas. Just something else to look for now.
Lawrence
bjones5's Avatar
bjones5 bjones5 is offline
Send a message via MSN to bjones5
Originally Posted by mcyr
Sorry;
Marcel
I must be going blind here Marcel........I cant see any obstruction of the 2X4, but I can see some destruction
Brian Jones,
226-662-0152
mcbridesown@hotmail.com
To all newcomers,
"Ceade Mille Failte"
(Gaelic for "A Hundred Thousand Welcomes")
Old 3/18/08, 7:04 PM
Old 3/18/08, 7:10 PM
bjones5's Avatar
Speaking of 2X4, is that chimney pipe rated for "0" Clearance?
Brian Jones,
226-662-0152
To all newcomers,
Old 3/18/08, 7:58 PM
I will try to read the label when I deliver the report next week.
Lawrence
Old 3/18/08, 8:01 PM
That's just fine. But there's no B-vent (that I'm aware of) that is listed to be in contact with, or wrapped with insulation of any sort.
Jeff Pope
Santa Clarita CA
(661) 212-0738
Old 3/18/08, 8:12 PM
Charley L. Bottger's Avatar
I nailed this one yesterday someone is going to have a lot of fun removing that insulation need to have wings
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 3/18/08, 8:38 PM
bdoles2's Avatar
bdoles2 bdoles2 is offline
Bad photo etiquette...Your foot is in the picture, now they'll blame you for it. LOL
I'm sure someone will get in there with one of these, grab the insulation and get rid of it, instead of placing it back where it belongs.
Old 3/19/08, 6:50 AM
Banned
Lawrence
Was your wood stove installer WETT certified. If he was, he should retrain on this topic. For manufacturered chimneys, follow the manufacturer's instructions. With Class A (ULC Standard S604-oil, gas and some special wood appliances) and chimneys approved for most wood burning appliances (ULC Standard S629), it is standard that 2 inches to combustibles be maintained and no insulation be installed around them. They make a special attic radiation (insulation) shield to keep the insulation from being installed against the chimney.
If you're in an area where there's a bit of wood burning, consider WETT certification.......the course is an eye opener......even for certified masons!!!!
Difficult Chimneys thance Inspecting HVAC Systems 2 1/29/08 8:16 PM
Chimney flashing photo's needed: brick and stone done correctly kshepard Exterior Inspections 6 10/13/07 8:10 AM
Vaulted Ceiling Insulation rcooke Canadian Inspectors 4 1/22/07 12:24 PM
New Old Insulation rcooke Canadian Inspectors 1 12/13/06 5:25 PM
Fireplace Enclosure jpope Interior Inspections 19 10/25/06 5:08 PM
