This was from today's Inspect don't even want to start the write up, its going to be nasty
No safety pan under A-coil Return air duct separated allowing attic air into return Supply air duct separated and crushed at coupling The return air blower compartment not sealing allowing return from attic Burners were rolling out The supply plenum had been added on to accommodate an added on area of the home and was robbing most of the air for the original section of the home. This was a 1979 Rheem and the Delta T was 20 degrees hard to believe Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging Last edited by cbottger; 5/13/08 at 10:19 PM.. |
I would like to see what you write up on that. To me it would be an easy write up. 2 maybe 3 sentences is all.
looks like an old Premier or Rheem horizontial style furnace,, will more than likely have a cracked HE close to the pilot,, look in the dimple, ducting loose, and crimped. AC coils not incased properly. Correct as needed.
Furnace has cracked Heat Exchanger. Ducting loose and crimped. AC Colis not properly incased. Replace and repair heating system as needed. Short and sweet and to the point. |
bbenjamin is a non-member guest and is in no way affiliated with InterNACHI or its members.
Charley,
Find the installer of this crappy system and get your consumer their money back entire job is shot to hell and a hand basket. |
</IMG></IMG> Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
| We arranged to send you some junk mail. Your contact info was not given out. | gromicko | Special Discounts for InterNACHI Inspectors | 1 | 7/24/07 1:38 PM |
| Some junk mail from NACHI and Bank of America coming. | gromicko | Special Discounts for InterNACHI Inspectors | 0 | 4/4/07 1:06 AM |
