Rick Vollmer is a non-member guest and is in no way affiliated with InterNACHI or its members.
I am not sure if it is freeon or what, but I have a rather good water leak coming from the pipe (copper) coming in from the out side unit running to the central air unit in the furnace which is in the upstairs of the house. The line runs under the floor joists in the crawl space up to the furnace. I just noticed the leak while I was in the crawl doing other work. The insulation around the pipe is really wet and dripping onto the plastic making a good size puddle of water.
My questions are: Can I remove the insulation, find the hole and patch it for now with plumbers expoxy? I really don't think this is a matter of condensation dripping, but I could be wrong (again). The pipe was really put in badly by the installer and it is over 20 years old. (Has a lot of bends and held against the joists by metal strapping). Also, can the pipe be replaced by myself or do I need to call in a plumber? If it is a DIY project, what are the steps and precautions that I need to do/take? Thanks for any input as I really can't afford to call in a plumber due to many other problems I have had. I can replace copper plumbing lines and have the pipe and tools, but I don't really want to solder on anything that might explode, if you know what I mean. Thanks again |
| Find an InterNACHI certified Minnesota Home Inspector (and anywhere else in North America) |
Rick,
If what you are seeing is water than it must be condensation as there is no water inside the system only gas and a small amount of oil. Re-insulating the pipes would be a good idea as that would slow the rate of condensation and increase efficiency. Regards Gerry "To realize our true destiny, we must be guided not by a myth from our past, but by a vision of our future." (Mark B Adams) Commercial property Inspection Tampa, Orlando, Sarasota, Jacksonville, Ft Launderdale, Miami, Florida. NACHI cell 484-429-5466 NACHI02121106 |
All insulation on the refrigerant lines should be glued to prevent this.
Water is condensing on exposed pipe (somewhere) and flowing down hill. Insulate everything. Refrigerant will not leak out in a liquid state at atmospheric pressures. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
Do not cut the pipes!!, you will loose all you refrigerant, you should call a qualified contractor if you fell uncomfortable.
Thanks for all the reply's. I think the condensation that I spotted is the reslut of my doing a lot of pipe insulation and now the condensation as found a new place to go.
I will take the advice and remove the metal strap holding the pipe and insulate around the pipe and re-secure using nylon straps that are use for ducts. Thanks again |
| Plumbing Supply Tubing | rroeske | Plumbing Inspections | 17 | 1/15/07 10:14 AM |
| supply in slab or walls? | jeubank | Plumbing Inspections | 1 | 7/8/06 11:36 AM |
| Grounding the gas line | dmacy | Electrical Inspections | 18 | 3/14/06 11:47 AM |
