Old 1/16/13, 5:57 AM
Buck Hartley, CMI's Avatar
Buck Hartley, CMI Buck Hartley, CMI is offline
Default Lennox Furnace
Need help with the age of this LENNOX furnace - model # G24H2-7A-27.
Thanks
Mid America Property Inspections, Inc.
Shawnee, KS 66216
www.mapii.com
NACHI # 05110992
KS-Radon Cert.# KS-MS-0035
KS-Termite Cert. # 18933
M0-Termite Cert. # N 5033
Need a home inspection in North Carolina? Check out InterNACHI's listing of North Carolina certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/16/13, 6:17 AM
Stephen W. Stanczyk's Avatar
Stephen W. Stanczyk Stephen W. Stanczyk is online now
Default Re: Lennox Furnace
Model # doesn't do much. What is the Serial #.
http://www.buildingcenter.org/lennox
Stephen Stanczyk
Old 1/16/13, 11:31 AM
Did not find one. My PRESTONS does not show this model number.
Thanks
Shawnee, KS 66216
www.mapii.com
NACHI # 05110992
Old 1/16/13, 11:50 AM
Cameron Anderson's Avatar
Cameron Anderson Cameron Anderson is offline
Serial number on many Lennox furnaces from the 80s and 90s were often printed on a separate sticker below the main data plate. They're often faded, fallen off or easily overlooked, do you have a photo of the furnace itself with the cover off?
Cameron Anderson
Integrity Home Inspection
Truth. In Real Estate.
Since 2004
Bachelor of Architecture, U of I, Urbana IL
Illinois Licensed Inspector
www.aaintegrityhomeinspection.com
www.homeinspectionpeoria.com
Old 1/16/13, 11:54 AM
William Warner's Avatar
William Warner William Warner is offline
Lennox doesn't list a G24H series... but does list a G24M.
Are you sure you transcribed the numbers and letters correctly?
Old 1/16/13, 1:35 PM
Look at the photo, G24M!!!! Sorry
Shawnee, KS 66216
www.mapii.com
NACHI # 05110992
Old 1/16/13, 2:48 PM
According to Preston's, G24M2 series units were manufactured from 1993-2001 regardless of the letters and numbers after G24M2
Probably the best you're going to get without the serial number.
Like Cameron indicated, the serial number sometimes was on a separate paper tag.
I wouldn't get too hung up on determining the precise age of a unit... just call it as you see it and recommend servicing/repairs if deemed necessary. It's likely an older unit anyhow and should be professionally serviced if it hasn't been routinely and professionally maintained.
Old 1/16/13, 5:06 PM
Thanks
Shawnee, KS 66216
www.mapii.com
NACHI # 05110992
Old 1/17/13, 1:35 AM
BTW, I've replaced three of those furnaces within that age range and every one of them had multiple cracks in the heat exchanger at the same locations.
Cameron Anderson
Since 2004
Need Date of Lennox Co Furnace (SR? 00 or 01 ?) Ja Florian Inspecting HVAC Systems 1 3/28/11 12:14 AM
Lennox Electric Heat Furnace salstad Inspecting HVAC Systems 1 7/18/09 11:17 AM
Age of Lennox Furnace bhartley Inspecting HVAC Systems 3 12/11/08 5:06 AM
980 Questions/Answers to the NHIE....Free! jbushart Legislation, Licensing, Ethics & Legal Issues for Inspectors 50 4/20/08 1:26 AM
Lennox Pulse furnace dmacy Inspecting HVAC Systems 4 4/6/07 6:14 AM
