jvogan is a non-member guest and is in no way affiliated with InterNACHI or its members.
Today's inspection. Home built in 1935. This furnace had virtually no info on the plate. Only info is: Lennox "Aire Flo", "Type 514", "No. 3", "Style 21".
Any help on the age of this unit would be greatly appreciated! |
I have called them before, very helpful people if you have enough info for them to help. 1-800-9-Lennox
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
Jeff,
When I run into a furnace that age and the date can't be deciphered, I note any defects and insert the following statement... The heating system was paced through it’s normal sequence of operating modes, with no obvious defects noted at time of inspection. However, due to systems age, it is clearly beyond it’s life expectancy, and replacement should be considered. Until then, I recommend annual maintenance from a licensed contractor. |
Thanks guys!
Some of my research indicates that prior to 1972, the type was the manufacture date, so I would guess April 1951.
| Age Lennox furnace | smcintire | Inspecting HVAC Systems | 3 | 11/14/07 9:38 PM |
| Age of Lennox Furnace | bhartley | Inspecting HVAC Systems | 2 | 11/5/07 7:19 PM |
| Lennox Pulse furnace | dmacy | Inspecting HVAC Systems | 4 | 4/6/07 6:14 AM |
| Age of Lennox furnace | lgerving | Inspecting HVAC Systems | 4 | 9/16/06 11:04 AM |
