I had two inspections yesterday that had a reduced size high pressure line. The high pressure copper line that was run through the wall and attic to the air handler was reduced to 1/4 inch and was soldered to the 3/8 line at the unit (before the dryer).
Is this normal? is this an issue? almost all the units I see have 3/8ths or better. |
| Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Need unit specificationand length of line set.
Though someone will give you some sort of nonsense about this, the least amount of refrigerant you have in the system the better off you are in accordance with system design. I know you don't want to do HVAC evaluations, but if you measure the temperature of the line set before and after the liquid line where it goes from 1/4 inch to 3/8 of an inch you should not get a temperature drop. This testing must be conducted under maximum design temperatures for your area. If you don't have maximum design temperature, then you are not required to perform the evaluation as this is not your job. If you want to cover your butt, you can always mention the fact in your report and advise the client that should the equipment capacity loss be observed, this is a possible solution to be considered. 1/4 inch liquid lines were commonplace and only units. Many of these lines pass through closed in walls and cannot be accessed for replacement. Is the existing equipment a heat pump? If so, this can be more of an issue and if it is not. "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
The short of it is no You are not allowed to decrease the MFG outlet size of the unit increase yes decrease no. I have posted PIC's on this before I write them up every time I see this.
| Condensation Drain line question | acassady | Inspecting HVAC Systems | 25 | 2/26/12 11:40 AM |
| Selected Electrical Incidents and Occurrences - First Quarter | pabernathy | Electrical Inspections | 0 | 12/2/07 1:43 PM |
| Question about Determining Electric Service Size | sbelda | General Inspection Discussion | 2 | 8/18/07 2:48 PM |
| Adequate service size....oh, and a GFCI question | ksherstobetoff | Electrical Inspections | 13 | 2/8/07 1:18 PM |
| Size of supply line | aobrien | Inspecting HVAC Systems | 7 | 1/2/07 12:40 PM |
