Ok lets do another simple question how many test a heat pump in the normal heat mode with an outside ambient at 90 degrees yes or no is sufficient
| Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Well, it depends Red Top, I've never run across a heat pump here.
BPI Certified Professional Building Analyst BPI Certified Envelope Professional Infraspection Institute Certified Level II Thermographer # 8510 www.dapkusinspections.com www.chicagoinfraredthermalimaging.com www.mychicagohomeinspector.com www.commercialbuildinginspectionchicago.com Professional Infrared Network Chicago Energy Audit Aerial Infrared Inspection Certified Infrared Thermal Imaging |
"Can the occupant of a home operate an appliance, using normal controls and at any given condition, whether proper or not?" ??? Or... "Is there a sign on the thermostat with instructions to not turn on the heat when too hot, or to not turn on the A/C when too cool" ??? Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Should I?
No I don't. Because it a heat pump and it 90 outside, I won't get an accurate reading so I tell them I did not test it in the heat mode.
I'm going up soon, maybe this week.
I can appreciate you saying it would not be an accurate reading because it would not but you also don't know if the reversing valve works, is that the only reason you do not test
Ok no one is doing much talking hiding in the bushes I guess so here is the reason I made these two loaded questions.
There is no difference in operating the A/C unit with a indoor ambient of 90 degrees and operating a heat pump in the heat mode with an outdoor ambient of 90 degrees you get the same results. So when someone tells me they don't operate a heat pump in the summer time in the heat mode even for just a test they basically don't understand the refrigerant cycle Freedom Express Inspections LLC CMOR Thermography Certified Level III #8486 freedomexpressinspections.com www.oklahomathermalinfraredimaging.com freedomexpress495@att.net NACHI Member Okla. State DEQ Environmental Phase One Certified Master HVAC Mechanic (Retired) Certified Universal Freon by 40CFR 82 Sub-part F State License # 130 Serving the States of Okla, Texas, Kansas, Missouri , Arkansas and New Mexico with Commercial Inspections,Thermal Imaging |
Is there enough pressure differential for the reversing valve to operate in those conditions?!
I'd guess so. Now someone mentioned tripping the head pressure safety and you'd have to figure out hot to re-set it! "Push the big red button"! If it don't got one, it's auto-reset... "Insanity: doing the same thing over and over again and expecting a different results." Albert Einstein Clarksville - Nashville Home Inspector Lic#40 http://www.midtninspections.com ITC Level III Thermographer Cert#1958 Building Science Thermographer Cert#33784 http://www.thermalimagingscan.com HVAC Certification EPA Cert#2046620 Link to my Website at: http://www.midtninspections.com/link-submission |
| A loaded question | cbottger | Inspecting HVAC Systems | 35 | 10/6/11 9:59 AM |
| Question for all... | Bob Hopton-Jones | General Inspection Discussion | 9 | 4/6/07 7:43 AM |
| Basement Bathroom Venting Question | Sean M. Jeric | Plumbing Inspections | 4 | 3/20/07 11:56 PM |
