I was going to write up lack of fresh air supply to furnace and also write up air vent in attached garage to attic till I took a closer look and saw down to the laundry utility room on other side of the garage holding the furnace .
Any opinion Good/or bad ?
| Need a home inspection in District Of Columbia? Check out InterNACHI's listing of District Of Columbia certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
OK to take make-up air from an attic but this implementation is not proper nor is it OK to have an opening from the garage into the attic if the ceiling is providing fire separation.
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
Thanks,I just never saw it done this way.
Here's what it looks like when done properly, but still can't be done through garage ceiling.
Thanks,however I mentioned in the first post that it goes into the utility room and not the garage.
Just fooled me at first as utility room is in wall behind the garage and not part of it. They had the secondary vent at the floor into the crawlspace which of course fooled me on first glance as being a return. |
Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
You need a shoe shine. Better yet buy a pair of new shoes with all that money you're making cheap azz.
In high winds, the attic may go under a negative pressure sucking air (and heat and moisture) out of the furnace room- the opposite of what the vent was intended for. Also, in the cooler seasons, warm air rises so this will actually be a heat loss from the home as well as possibly introducing moisture from the laundry/utility room to the attic where you don't want it. |
That would keep it balanced from my perspective ,unless you have more on that. *4 year old lady buying and will learn to live with everything but the stupid green brillo pad filters stuck in the duct above the exchanger . You actually need to stick your arm inside after removing the front panel.(so stupid a design). Will put pic in a bit as I am trying to wrap up the reports and get out of Dodge in the morning. www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 7/2/10 at 10:46 PM.. |
Thanks Dale.
I love those shoes and they are dirty because someone has to work for a living. (get out and inspect some crawls you lazy bastard.) This was in your Linus land of Orland Park by the way and I left my Infra Red Thermometer there. 49 miles away darn it. www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 7/2/10 at 10:45 PM.. |
I just completed a mold remediation job. I actually worked 32 hours on this one!! Pays a lot more than inspecting!! I bid it, remediated it and billed it.
Condo
I think I can only remember one set of Pull Down Stairs in a garage installed correctly, you guys probably have the same do-it-yourself-ers there I'd bet--- Dale Duffy Inspect Arizona Companies, Inc. Phoenix Commercial Building Inspectors, Inc. Phoenix Thermal Imaging, Inc. Infraspection Certified Thermographer 602.402.5305 Home Hints eNews
| Roof decking condensation. | Homewood | Interior Inspections | 15 | 3/5/10 11:00 AM |
| Mold question? | ccurrins | Interior Inspections | 35 | 1/23/09 11:55 AM |
| Truss Uplift | rcooke | Canadian Inspectors | 5 | 2/26/08 7:43 PM |
| Spray Foam to the Rescue ? | mcyr | Structural Inspections | 3 | 3/27/07 7:29 PM |
