Old 1/22/10, 9:05 PM
Bruce A. King's Avatar
Default how many would write up this
2nd time this week I have found the small refrigerant line partly crimped next to the airhandler unit.
This one was written up months ago during a predrywall inspection and its still the same during the final inspection.
Anyone know the tolerance on this?
www.BAKingHomeInspections.com
704 301-3207
Need a home inspection in Michigan? Check out InterNACHI's listing of Michigan certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 1/22/10, 9:10 PM
Default Re: how many would write up this
David Andersen will probably know...he'll be around.
Larry Kage, CMI
231 929 3525
Old 1/22/10, 9:11 PM
I just looked at the picture taken during the predrywall and it looks better then! They actually made it worse since then!
704 301-3207
Old 1/22/10, 9:38 PM
wsiegel wsiegel is offline
I will always write that up.
Old 1/22/10, 9:44 PM
iniquette's Avatar
iniquette iniquette is offline
Send a message via ICQ to iniquette
I would. It is crimped,which will restrict flow,which may in turn affect the operation of the unit.
Ian Niquette
Square One Home Inspection
Markesan WI 53946
www.squareonehomeinspection.com
Active Rain Network
INACHI Awards Portal
Want To Exchange Links?
What we've got here is......failure......to communicate.....
Old 1/23/10, 12:44 AM
Steven J. Wessler Steven J. Wessler is offline
Pressure Readings
Steven Wessler
SpyGlass Inspection Services, LLC
Serving The Lake of the Ozarks, Missouri
INACHI: 09021806
www.spyglassinspect.com
Old 1/23/10, 2:09 AM
Russel Ray's Avatar
I don't know the tolerance on it, but I would write it up.
Old 1/23/10, 7:58 AM
rarmacost rarmacost is offline
I would wright it up, another question is, should you be concerned about the copper line coming in contact with the galvanized siding of the unit?
Old 1/23/10, 8:24 AM
David P. Valley's Avatar
Tolerance is not the issue. It's just plain shoddy workmanship at this connection. Recommend an upgrade.
Old 1/23/10, 1:29 PM
James E. Braun, CMI's Avatar
Ya, all you could say is it lacks professional workmanship. Workmanship like that is preety common in my area. I really would doubt it would effect the future operation of.
How do you write up an open neutral mnahrgang Electrical Inspections 7 8/4/08 9:08 PM
Tidbits from the ASHI Message Board jbushart Miscellaneous Discussion for Inspectors 124 4/27/07 12:05 PM
