When there's mechanical equipment located in the attic space, it shouldn't be further than _____ feet from the attic access.
What's your answer? (Don't look it up! Anybody can do that. Take a guess.) |
| Need a home inspection in Massachusetts? Check out InterNACHI's listing of Massachusetts certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
20 feet
Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
When did the 20' rule take effect? Had a 1990 home that had equipment at least 40' away. It was called out.
Richard W. Washington, owner RW Home Inspections, Inc. www.RWHOMEINSPECTIONS.com Texas Real Estate Commission (TREC) Professional Inspector License #7238 Texas Professional Real Estate Inspectors Member (TPREIA)-Greater Houston Chapter InterNACHI member since 2004 Based in Katy, serving Houston and all surrounding communities |
I had no idea there was a footage rule for mechanical systems in the attic, as long as there's access. Let me guess....10 feet?
20ft
I'm in the middle of taking the advanced HVAC course, the answer is 20'. I did not know this before. Can anyone tell me why 20'? Why does it matter?
David InterNACHI #08051301 NYS Lic. #16000038229 NYS DEC Cert # T4865884 518-505-8305 HouseAbout Home Inspections HouseAbout on Facebook NY Capital Region Chapter InterNACHI |
20 feet. UNLESS there is adequate headroom, then it is more. I can't remember the headroom requirement but I believe the minimum is either 6 feet or 6 feet 6 inches because I can stand up.
I hate attic installations, especially in the summertime. Nothing worse than a 150 degree attic, furnace installation at the far end and a sheet metal cover on the work platform. Stephen Stanczyk Washington State Licensed Home Inspector # 221 President, Washington Association of Property Inspectors (WAPI) (253) 241-0602 calls answered until 10pm Pierce County -Thurston County - King County - Snohomish County |
There must be a "passageway" at least 30 inches high and 22 inches wide and not more than 20 feet in length. Decking in front of the HVAC equipment must be at least 30x30 inches.
I call it out when there is no decking on the passageway. The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life. Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
The Mechanical equipment should be made accessible from the attic access panel area or a catwalk provided to reach the area of the equipment, along with light switch and light and a service receptacle. Am I close.?? LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
You're 20 feet too close.
Well then, looks like you need to build me a catwalk to get there.
Well, since you peeked and were not supposed too!
Question: If a furnace or air-handling unit is installed in the space above a lay-in or drop-in ceiling, does Section M1305.1.3 "Attic Furnace" apply? Section 1305.1.3 requires a catwalk, access, work platform, electric outlet and light. The context of this provision of the IRC indicates that this section of the code refers to an attic space which is an area created between a permanent ceiling and the roof of the structure, not a space above a drop in ceiling.
Additionally, note the exception in Section 1303.1.3 of the IRC that states: Exception: A working platform need not be provided when the furnace can be serviced from the required access opening. The furnace or air-handler may be accessed through the lay-in or drop-in ceiling and the supporting grid assembly. The grid is not part of the permanent structure and may be easily removed for servicing or for the removal of the equipment. Therefore, air-handling equipment installed in the area between a lay-in or drop in ceiling and upper floor or roof assemblies need not comply with Section 1303.1.3. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
I just want to make a point here;
First of all, we are not Code Enforcement Officers (C0E) and the limitation of a 20 long walkway is based on the written fact that the minimum height is only 30 high. A little common sense here has to be applied. First, if this is an old house, there will be no catwalk. Watch your step. If this is a new House that applies to the IRC, well fine, if you want to enforce the code, go right ahead. The mechanical equipment is either going to be readily accessible or it is not. At 30 high, having to crawl more than 20' would not be readily accessible. Damn, I don't think I could make it that far. Most of the framing in attics is 24 on center, now to me that leaves 22&1/2 in between the framing, so 22 catwalk would not be economically feasibly to me if I were to frame it. All I am trying to point out, is that these codes are minimum requirements and a little common sense should be used in calling out stuff. The codes will not apply to every individual variable out there. I have had catwalks that are over 300 ft. long. But I could stand up and walk, and they were 24 wide not 22. Further more, if a Mechanical Contractor wants to install his equipment 20' away from the access point at 30" clearance, he is crazy. LEED Green Associates InachiAwardsPortal: Inachi US Member of the Year Award 2009 |
Marcel, I'm inclined to agree. I'm not a stickler on the 20 foot rule and have never called that out. I do, however, call out the absence of a decked passageway and the absence of an adequate deck in front of the equipment. I also call out the absence of a light and outlet near the equipment (in attics and crawls).
I've seen furnaces jammed in trusses so tight a midget couldn't get to it to work on it properly. I realize me calling out an 'inaccessible' furnace won't change anything. But at least the buyer is made aware. The things that will destroy America are peace at any price, prosperity at any cost, safety first instead of duty first, the love of soft living, and the get-rich-quick theory of life. Theodore Roosevelt Joe Funderburk, CMI Alpha & Omega Home Inspections, LLC Inspecting Upstate SC & Charlotte Metro, NC NACHI ID: NACHI05120170 www.aohomeinspection.com |
| Help. What is the correct way to report a breaker that is too big. | gromicko | Electrical Inspections | 77 | 5/10/12 6:13 PM |
| What do you think? Can this work for you? | jtedesco1 | Electrical Inspections | 21 | 2/26/11 2:00 PM |
| Where is it written.... | bgromicko | General Inspection Discussion | 21 | 1/19/08 9:02 PM |
