Old 7/11/11, 8:02 AM
George E. Russell George E. Russell is offline
Default Mildew on mastic @ plenum 10 month home
Is it common to start seeing mildew on such a new home? I've seen it time and again on older homes but what could cause such staining on a 10 month old home? Lack of filter changing??
George Russell
George Russell Professional Inspections
Austin,Texas
TREC # 10215
512-296-9538
http://georgerussellprofessionalinspections.com/
http://www.facebook.com/austinhomeinspections
Need a home inspection in South Dakota? Check out InterNACHI's listing of South Dakota certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/11/11, 8:09 AM
Linas Dapkus's Avatar
Linas Dapkus Linas Dapkus is offline
Default Re: Mildew on mastic @ plenum 10 month home
Condensation.
Old 7/11/11, 8:11 AM
But common this early on?
George Russell
Austin,Texas
TREC # 10215
512-296-9538
Old 7/11/11, 8:43 AM
Banned
If the duct is insulated, could be a gap in insulation allowing cooling /condensation at the seam.
Old 7/11/11, 9:49 AM
Doug Edwards's Avatar
Mildew (mold) doesn't know (or cares) how old the home is. If conditions are right it can form in a matter of a day or two (36 hrs in one article I read recently).
- John Stuart Mill
Old 7/11/11, 10:00 AM
Roy D. Cooke, Sr's Avatar
New homes are loaded with moisture and can take years for to balance .
Wet cement green lumber .
Drywall gets painted and with the paint sealing it to can take a long time to loose all its moisture .
A dehumidifier set below 50% will help big time and have it drain with a hose .
Old 7/11/11, 10:27 AM
David A. Andersen's Avatar
It is not likely that you can prevent mold on this appliance (regardless of where it is located) when condensation can form on the air duct with a relative humidity is low as 12%.
Moisture + humidity (at the correct levels) = mildew
This is a fiberglass duct board connection which seldom has an adequate seal to the equipment. (One of the drawbacks for this application)
BPI# 5015804
Old 7/11/11, 12:39 PM
Banned
This is a fiberglass duct board connection which seldom has an adequate seal to the equipment. (or from duct piece to duct piece)(One of the drawbacks for this application)
We don't have that material in my area (or I haven't seen it yet).....all metal. When I looked at the picture, could not tell if it was metal or not.
Would make sense then that a bad cut of the material and/or a poor connection with even a small gap between duct ends would cool the mastic leading to what's seen in the picture.
Old 7/11/11, 12:45 PM
Yup, basically this duct is taped to the unit from the outside, allowing conditioned air directly against the mastic.
BPI# 5015804
Old 7/11/11, 12:46 PM
Banned
In looser, new homes from pre-1975, it usually took 18 months or so for the bulk of moisture to leave the home. Then the home would go through the usual seasonal uptake/and then release of moisture from summer through to winter/spring.
With well designed/installed HRV's/air exchangers, the bulk of moisture could be removed from the home within 2-3 months. In 1987-8, a couple of the HRV manufacturers added extra low speed controls to their units so houses would not be overdried in Jan/Feb.
Old 7/11/11, 6:52 PM
Russell J. Hensel's Avatar
Russell J. Hensel Russell J. Hensel is online now
We see this on a daily basis. Typically what it is (and by the pictures) where the insulation board meets with the plenum, there is a gap and causing the cold air to escpape, thus creating a cold seam. It LOOKS as though this is in an attic area. Depending on the humidity and temperature it may only take a few degrees differential to reach dew point. Yous tart reaching dew point, you start making condensation and then you start making mold. The uniformity appears to be a compromise where the ductboard meets the plenum. Easy fix, have the HVAC technician come back and ensure the seam is insulated to prevent cold air from leaking out at the seams. This usually takes care of it.
Comprehensive Building Consultants
Naples Home Inspection, Naples Mold Inspection, Naples Radon Inspection, Bonita Springs Home Inspection, Bonita Springs Mold Inspection, Bonita Springs Radon Inspection.
Donate here:
or send checks to the
Fl Home and Insurance Inspector Chapter
1103 W Hibiscus Blvd Ste 311
Melbourne, Fl 32901
Old 7/12/11, 10:04 AM
Don't wast your time and money on an HVAC guy (Russell is just trying to help Obama stimulate jobs), that is not leaking.
It is a thermal bridge not a thermal bypass.
If you really want to know, spend $30k on IR...
BPI# 5015804
Inspector Wendy's Home Inspections-Service Areas wforsyth Miscellaneous Discussion for Inspectors 57 9/5/06 11:10 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
