Old 2/6/12, 8:27 PM
Darin Redding's Avatar
Darin Redding Darin Redding is offline
Default Min. vert. distance from w/h exhaust and operable window
I believe the minimum allowable clearance from an exhaust vent termination above an operable window is 12". That sound right?
I have a 50 gal. conventional water heater in a garage vented out a side wall of a two story residence, the diagonal distance from the corner of the operable portion of the window to the vent is about 24".
Darin Redding, CPI
Housecall Property Inspections
san diego home inspection
rental inspection | warranty inspection
Facebook Like
darin@sandiegohomeinspect.com
619-663-8740
home inspector in San Diego, Carlsbad, Poway, La Mesa, El Cajon, Chula Vista.
Need a home inspection in Kentucky? Check out InterNACHI's listing of Kentucky certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/6/12, 9:03 PM
Christopher Currins's Avatar
Default Re: Min. vert. distance from w/h exhaust and operable window
Fuel appliance exhaust, excluding direct vent, should terminate at least four feet below or horizontally from door, window, or air inlet.
Christopher Currins
Certified, Licensed
Old 2/6/12, 9:04 PM
Stephen W. Stanczyk's Avatar
Taken from a Rheem direct vent water heater installation manual:
Vent Termination must be at least 9" from windows, doors, or any other opening through which flue gases could enter the building.
9" for less than 50k btu
12" for more than 50k btu.
Depends on if it is a direct vent appliance.
Stephen Stanczyk
Old 2/6/12, 9:13 PM
Chris - thanks, I have that same image! It is a good one, I refer to it often. In this case though, the vent terminates above the operable window. Btw, how is the home-wizard working out for your business? Looks interesting.
Stephen - This is not direct vent, but a conventional Rheem water heater. I do not know the Btu, but suspect I could get it from the model #.
Darin Redding, CPI
Facebook Like
619-663-8740
Old 2/6/12, 10:19 PM
OK, if vent is above top of window opening and terminates at least 12" diagonally away from outside corner of window; that would classify as 12" vertically.
Christopher Currins
Certified, Licensed
Old 2/6/12, 11:16 PM
Thanks Chris.
Darin Redding, CPI
Facebook Like
619-663-8740
