Old 8/25/07, 9:56 PM
Shawn Rowe's Avatar
Shawn Rowe Shawn Rowe is offline
Default mis match Carrier split system
Is mis-matching heat pumps and air handlers allowed (allowed by Carrier)? I cannot seem to find any thing in black and white.
I had a 2 ton heat pump with a 2.5 ton rated air handler at todays inspection.
Thanks in advance!!!!
Shawn Rowe, CMI
HomeFirst Inspection Services, LLC
- InfraRed Specialist (Level 1 & Building Science certified)
- Code Certified Residential Building Inspector
- Certified Master Inspector
-- Serving NE Florida, St. Johns, Duval, Flagler, Putnam counties --
Old 8/25/07, 11:13 PM
wsiegel wsiegel is online now
Default Re: mis match Carrier split system
Shawn,
Are you talking about heat pumps or a central air split system. Many times I have seen the air handler be .5 ton higher than the condenser unit. This does not pose a problem.
Old 8/26/07, 12:10 AM
Joe Funderburk, CMI's Avatar
My state's SOP dosen't require me to report on system design and I don't feel qualified to do so. So I don't.
Theodore Roosevelt
Joe Funderburk, CMI
NACHI ID: NACHI05120170
www.aohomeinspection.com
Old 8/26/07, 12:57 AM
Charley L. Bottger's Avatar
A 1/2 ton over and a 1/2 ton under is generally exceptable under most circumstances. As an old mech I tried to keep them matched. I would much prefer the A-coil larger than the condensing unit if I had to make a choice. Just my thoughts.
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 8/26/07, 6:46 AM
Bruce M. Graham, III's Avatar
Bruce M. Graham, III Bruce M. Graham, III is online now
with carrier there is a device call an accurater that is a sized orifice that is selected based on the system, I have seen mismatched system where the wrong accurater has been installed. As a home inspector all you can do is make notes on what is observed and report. I agree with Charlie a .5 diff is not much of a problem and the inside section should be the larger of the two.
Bungalows to Mansions
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 8/26/07, 7:33 PM
David A. Andersen's Avatar
You must talk to the manufacturer.
Often when the client refuses to change the coil, the most appropriate unit is installed under the recommendation of the mfg.
If the unit is of different mfg. it is almost always grounds to void warranty.
New Washington Legislation Submitted gdomagala Legislation, Licensing & Legal Issues for Inspectors 293 2/10/08 2:20 AM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 6:58 PM
Massachusetts Board of Registration of Home Inspectors jtedesco1 Legislation, Licensing & Legal Issues for Inspectors 0 2/14/06 4:38 AM
