Old 2/5/10, 8:21 PM
Mark Thiltgen Mark Thiltgen is offline
Default Missing something here?
Looked at house today, furnace was vented out side with exhaust. But there was no intake as you can see. It is drawing air in as it almost sucked my dollar in there. I can't believe a HVAC person would do this if it wasn't ok, help me out here. thanks, Mark T
It's a 2005 Goodman furnace
Need a home inspection in Wyoming? Check out InterNACHI's listing of Wyoming certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 2/5/10, 9:05 PM
David A. Andersen's Avatar
Default Re: Missing something here?
Depends...
BPI# 5015804
Old 2/5/10, 9:09 PM
Stewart Mussolum Stewart Mussolum is offline
Hi Mark
This system is acceptable. What you have is a high effficency furnace that is what is called a two pipe system. The installer has the option of connecting the second, intake pipe to the outdoors or to leave it as you see it in your pic. The advantage of connecting it to the outside is that the air for combustion is not taking heated air from the home. Connecting to the outside is the better choice but the way it is installed is OK but in most cases you will see a screen to prevent larger objects from entering the the combustion exhaust blower.
Hope this helps
Old 2/5/10, 9:20 PM
It helps mucho grande!!! I really appreciate the way you guys respond to questions. I'm learning more everyday ( of course I'm forgetting more everyday also )
Old 2/12/10, 8:39 PM
Marcel Gratton's Avatar
There is an air intake pipe (black insulated) visible between the furnace and water heater; it provides combustion air for both appliances.
On The Level Inspection
Gatineau, Québec
Old 2/12/10, 9:12 PM
Bob Elliott's Avatar
It needs a screen.
It also needs good makeup air around it.
Best practice is to draw from near the exhaust due to pressure differentials however.
If that is a utility closet ,rule of thumb is 1sq inch opening per 1000 BTU's.This would mean total including that HWH next to it.
Just to be clear I was referring to vent opening like on a closet door and it should have two openings to stimulate circulation. (near the floor and at the ceiling area or top of door frame).
Old 2/13/10, 1:15 AM
Paul Pendley Paul Pendley is offline
Nope....that is wrong.
Paul Pendley
Premier Property Inspections
866-458-8516
Old 2/13/10, 6:08 AM
staylor5's Avatar
staylor5 staylor5 is offline
The system needs at least an elbow in the air intake. I would also make sure that there is a fresh air vent in that room.
Missing lintels? tpetersen Structural Inspections 8 5/17/09 8:40 AM
Will missing vapor barrier & unvented crawlspace make Radon levels elevated ? tchristopher Ancillary Inspection Services & Additional Topics 24 2/22/09 9:39 PM
Can you spot whats missing? belliott Inspecting HVAC Systems 13 2/21/09 11:20 AM
Locating Missing, Damaged, Settled or Wet Insulation inxil InterNACHI & RealMatcher Blogs 0 1/16/09 3:20 PM
Whats missing Here?? psmothers Inspecting HVAC Systems 7 3/18/08 3:25 PM
