Old 4/21/11, 8:03 PM
David C. Macy's Avatar
Default Mitsubishi Electic System
How do you determine the age for these systems?
Here is some info if you need.
First time on this system.
http://www.crc.nd.edu/~rich/JJW_Comp...i_brochure.pdf
http://www.mylinkdrive.com/MrSlim/M_...ice_Manual.pdf
ID:	44154   mitsubishi-electic-system-181311-001-small-.jpg.JPG
Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 4/22/11, 1:35 PM
William Warner's Avatar
William Warner William Warner is offline
Default Re: Mitsubishi Electic System
For Mitsubishi ductless units, I believe you have to contact the manufacturer.
When I encounter something I can't easily decipher the age, I simply recommend servicing and collecting all records from current owner. Don't waste too much time on determining age in your reports.
Visit the InterNACHI Awards web portal here
Blessed are the blissfully ignorant... for they shall be easily led...
Old 4/22/11, 1:40 PM
Michael Larson's Avatar
The MUM18NW is a residential split-system central air conditioner. Its efficiency rating of 10 SEER makes it a mid-efficiency model. (US Federal requirements specificy that no central air conditioners can be manufactured in the US with a SEER of less than 13.) High-efficiency models can reach a SEER of up to 21. The first year that this model appears in our records is 1999.
http://www.furnacecompare.com/air-co...i/MUM18NW.html
Michael Larson
Hudson, WI
Old 4/22/11, 6:52 PM
Thanks for the response.
I like to note the age of equipment on my reports. I know to some this seems irrelevent.
This Mitsubishi system was just supplimentary to the 2nd floor.
Expensive system!!
Old 4/22/11, 7:07 PM
Steven J. Wessler Steven J. Wessler is offline
Michael,
Kinda makes the US Federal requirements useless if we are gonna import less standard items. ????
Steven Wessler
SpyGlass Inspection Services, LLC
Serving The Lake of the Ozarks, Missouri
INACHI: 09021806
www.spyglassinspect.com
Old 4/22/11, 7:12 PM
Bob Elliott's Avatar
Does anyone else find it ironic they bought a MR Slim and then faced the wide side at the door?
Notice :the bolt down brackets are not fastened at the base.
Originally Posted by swessler View Post
Michael,
SEER 13 was not required until 2001 and and not enforced until 2004 due to court challenges by the industry.
So this unit may well have been legal at the time of install.
Michael Larson
Hudson, WI
Old 4/22/11, 7:14 PM
Mike ,look at the picture and tell me that is not a new install.
Old 4/22/11, 7:17 PM
It doesn't look new to me but that is irrelevant. It could have been a savaged unit.
Michael Larson
Hudson, WI
Old 4/22/11, 7:20 PM
Service Manuel published in 1997 though it is CSA verified.
http://www.mehvac.com/UploadedFiles/...0Technical.pdf
Old 4/22/11, 7:26 PM
This is not the main cooling system.
Its is supplementary to the main cooling system.
So why would it need to be 13 SEER?
Old 4/22/11, 7:28 PM
Probably not IMHO.
Edit: Best I can tell you can no longer by a mini split less than 13 SEER.
Michael Larson
Hudson, WI
Builders and Real Estate Agents Conspire to Kill Fire Fighters jbushart General Inspection Discussion 146 11/9/10 4:40 PM
IAC2 In new residential construction mcyr IAC2 Indoor Air Forum 0 10/9/07 6:45 PM
PIC of State Rep and sponsor of new NACHI H.I. Bill in NH. gromicko Miscellaneous Discussion for Inspectors 53 8/30/06 5:58 PM
