What are some of the problems associated with using black iron and galvanized pipe together for natural gas? THANKS!!!
Buck, you might want to check with various AHJs in your area and see what they say. Some will allow it, and some won't. Some will allow just a little bit of galvanized pipe.
Mostly, it's up to the Power Compnay to set the rules. "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Galvanized pipe is commonly used for water systems, black pipe for manufactured and natural gas.
I've never heard of galvanized piping for gas usage. As far as I know, Galvanized pipe should never be used for gas installations. |
Roy Cooke Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
Most jurisdictions do not allow galvanized because of the possibility of the zinc coating flaking off inside the pipe, and clogging orifices and valves.
down here all you see is galvanized, took a little getting used to after run black pipe for 14 years. That and the lack of a drip leg, or flex lines though the unit casing. Don't get me started.
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
One of the other reasons that galvanized pipe is not normally acceptable and the gas pipes are black is so that once someone removed the pipes they are not used for water lines.
Galvanized pipe is porous and absorbs gas. If later used for water lines, the water will be poisoned by the gas in the piping. Galvanized pipe is also not made to the standards of the black pipe. The galvanized pipe has flaws in it that are not acceptable in the black pipe. The gas is a smaller molecule then the water. Small leaks are a bigger problem with gas. Jason Sieg, CMI Davison, MI NACHI05091399 Knowing the current condition, to make a wise decision.
President, Great Lakes-East Chapter Join NACHI Great Lakes - East Chapter http://mi.nachi.org/greatlakes-east/about.html ssieg@gfn.org |
\ This web site also says never use Glavanized for Gas
http://www.acehardware.com/sm-learn-...g-1267591.html Galvanized pipe is commonly used for water systems, black pipe for manufactured and natural gas. Galvanized pipe should never be used for gas installations. Plumbing codes in many areas require that black pipe, especially that used underground, be coated and wrapped. Roy Cooke Need help on inspection call my cell 613-827-2011 I like email Roycooke@hotmail.com Never wrestle with a pig (however titled) as you just get dirty and the pig has all the fun. |
I've talked to the Ohio Gas service techs. in this area and they say O.K. to use either. Ill just keep using black myself.
"Buck, you might want to check with various AHJs in your area and see what they say. Some will allow it, and some won't. Some will allow just a little bit of galvanized pipe.
Mostly, it's up to the Power Compnay to set the rules." (Seems to me I just read that somewhere.) You wouldn't want to condemn it in a report if it is allowed --- or visa-versa... "not just an inspection, but an education" www.homesweethomecincinnati.com Democracy is two wolves and a lamb. Liberty is a well-armed lamb. B. Franklin |
Although it is not against UPC to use galvanized pipe for gaslines, there is a problem with connecting dissimilar metals. Electrolisis will occur anytime that you mix metals without using a dielectric union. Granted it won't happen as fast with a gas line as a water line, but it will happen.
gmaher is a non-member guest and is in no way affiliated with InterNACHI or its members.
Our gas/electric power company in eastern North Dakota (Excel Energy)will not allow galvanized pipe for their natural gas either. We just put in a gas heater and we know.
George Maher Home - Safe Home, LLC Fargo, ND |
I'm surprised to hear so many say it's not allowed. There may be some local ordinances that prohibit it, but the model codes allow it. I see it quite often. UPC 1210.1 Allows galv steel for gas piping. IRC G2414.4.2 Allows it as well. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
Well if I can't spell it, I ain't goin' there IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
| Do you put polybutylene in the Summary? | jfunderburk | Plumbing Inspections | 41 | 4/5/12 6:43 AM |
| Help - Polybutylene Pipes | Rick G | Plumbing Inspections | 39 | 2/12/09 8:16 AM |
| Identify ABS defective pipe | mcyr | Plumbing Inspections | 6 | 1/29/09 6:39 PM |
| Vent pipe | dlee2 | Plumbing Inspections | 4 | 9/17/07 11:28 PM |
