I have seen several heat pump units that have moisture on the mounting pad below the condenser. Is it a difference in temperature sort of thing causing the moisture? or -- is it a leakage problem?
Yesterday was overcast in 60's with a/c on. Previously seen in cold weather 30's when heat was on. |
jbreazeale is a non-member guest and is in no way affiliated with InterNACHI or its members.
Linda,
Moisture on the pad is normal, especially in heat mode. Coils on a heat pump have a defrost element that kicks in under certain conditions. The coils can ice over. The defrost thermostat kicks in under these conditions to keep that from happening. As for the a/c, condensate from the end of the suction line will always be there. There's nothing abnormal in either case. |
What Jimmy said.
Ibid
| IAC2 In new residential construction | mcyr | IAC2 Indoor Air Forum | 0 | 10/9/07 6:45 PM |
| What is a 'condenser' dryer ?? | rcooke | Canadian Inspectors | 9 | 9/9/07 7:02 PM |
