Old 7/24/11, 9:12 PM
Steve Rivers Steve Rivers is offline
Please Note: Steve Rivers is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Is my A/C evaporator broken?
Hello.
I have a Carrier air conditioner with the model # 38EH0363300L. My evaporator is an R22 model.
Recently, there was water on the floor around the A/C. An A/C repairman came to the house, performed an examination, and said that the evaporator has a crack in it and needs to be replaced.
We cleaned up the water.
About 4 - 5 days later, once again there was water in the vicinity of the A/C.
So, is there a problem with the evaporator? Or could there be a problem with something else?
Can the A/C still be used with this problem? Or should we replace the evaporator right away?
Thanks for any information.
Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine.
Old 7/24/11, 10:11 PM
Wayne B. Wilson's Avatar
Default Re: Is my A/C evaporator broken?
Try cleaning the drain out.
Wayne Wilson
East TN Home Inspections LLC
865-256-1490
Old 7/24/11, 10:12 PM
Check to see if it is iced over also
Wayne Wilson
865-256-1490
Old 7/24/11, 10:16 PM
David A. Andersen's Avatar
Need more information than that...
Can't do a service call over the internet with "I have water on the floor"...
There is 2 dozen reasons for water on the floor.
Scan and post his service peperwork.
BPI# 5015804
Old 7/24/11, 10:34 PM
Blow back through the a-coil drain hose/line. There may be a blockage in the drainage tray drain inside the a-coil drainage tray. It is the drain that comes out of the duct above your furnace for the a-coil hose/line. Make sure the a-coil drain hose/line to the floor drain is not blocked.
See this alot. This line/drain must be kept clean/clear, or moisture from the a-coil drainage tray will over-flow into your furnace/electronics.
CMI, CPI, KS #0110-0094 Termite #16601
KS Radon #KS-MS-0027
BBB A+ Accredited Business
Serving the Greater Kansas City Metro Area
Eastern Kansas/Western Missouri
http://www.metrospeckc.com
"If opportunity doesn't knock, build a door"--Milton Berle
Old 7/24/11, 10:52 PM
And while you're at it check for:
dirty evaporator coil
cracked condensate pan
unit not level
low refrigerant charge
restricted airflow from the blower
dirty filters
closed supply registers
collapsed air duct
detached cabinet insulation
construction filter left in the air handler unit
condensate drain line buried in the ground
condensate drain line not properly supported in the crawlspace
improper manufactured condensate drain trap
excessive negative pressure in the air handler
excessive dirt in the bottom of the evaporator coil pan
uninsulated suction refrigerant line
defective condensate pump
somebody unplugged condensate pump to use the outlet
GFCI breaker tripped on the condensate circuit
humidifier not turning off
BPI# 5015804
Old 7/25/11, 12:00 AM
Jeffrey R. Jonas's Avatar
Or...
Call a different HVAC service company for a second opinion.
Old 7/25/11, 6:53 AM
Originally Posted by jjonas View Post
Or...
Best advice LOL
Wayne Wilson
865-256-1490
Old 7/25/11, 10:58 AM
Robert J. OConnor's Avatar
Probably meant that the evaporator drain pan/tray has a crack. The replacement part may not be available for older units.
I agree with others who have stated to follow his advice or get a second opinion.
JMO & 2-Nickels ...
Robert O'Connor, PE
LIU CW Post Adjunct Professor
NACHI Education Committee
www.reporthost.com/-rjo
Old 7/26/11, 12:13 AM
Tim Spargo's Avatar
Kinda what I thought when he posted the info...
Also.. if water is getting on floor, it's likely doing *other things* to furnace/fau parts, if applicable.
Tim Spargo
Spec Rite Inspections
661-317-5770
