Old 6/20/06, 10:21 AM
pcarter-old-04's Avatar
pcarter-old-04 pcarter-old-04 is offline
Please Note: pcarter-old-04 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Need Assistance on A/C Unit
Did an inspection on pre-manufactured (double-wide) home late yesterday. The A/C unit did not have a manufacturer specified on Unit or Mfg tag. The furnace was a coleman. The model # on A/C Unit is BRCO0481BD with a S/N of 010322259. Also need to find tonnage of A/C. The home was manufacturered by Hart Housing Group of Indiana in August of 2001.
Does anybody have any idea who the A/C Unit was manufacturered by. I ran it through Preston with no luck. The people at HArt did'nt know. Your help would be appreciated. Thank you in advance.
Old 6/20/06, 10:45 AM
gbeaumont's Avatar
Default Re: Need Assistance on A/C Unit
Patrick,
I believe that you wrote the model # down incorrectly, I think you are looking at an Airpro BRCQ0481BD which is a 2001 4 ton unit
Regards
Gerry
(Mark B Adams)
NACHI cell 484-429-5466
NACHI02121106
Old 6/20/06, 10:48 AM
By the model number, it looks like a four ton unit. Must've been a big mobile!
The manufacturer company is probably listed at the bottom of the tag in very small print. Usually a trick of Inter City products, or Goodman/Janitrol, which would not necessarily be the brand name on the unit.
Old 6/20/06, 12:20 PM
JLilly's Avatar
JLilly JLilly is offline
Blaine is right about that. Intercity is bad for no name units. You bought a Mc Unit No brand tag at all.
Old 6/20/06, 1:30 PM
ccbrands1 ccbrands1 is offline
Please Note: ccbrands1 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Patrick,
You may know this already, but the 48 in the model number gives the tonnage away. Most manufacturers use this system.
Look for multiples of 12 in the model number for tonnage
48 / 12 = 4 tons
54 / 12 = 4.5 tons
etc..
Old 6/20/06, 2:43 PM
Everybody thanks for the help. No mfg was on that tag which really surprised me some, usually thaey give some good clues as who put the unit together but not in this case. Yep, Gerry, you are probaly right about the O being a Q, since all the other numbers matched up, I will go with the mfg you listed. The unit requires servicing anyway and I am telling them to have it serviced because of crimp in the supply line and noisy fan (bearing going bad sound). So the HVAC Tech can have a go at it as well. The tonnage is a bit much for a 1680 sq. ft. double wide.
Old 6/20/06, 7:31 PM
On your typical 1600-1700 sf house in this area a 4 ton would be overkill. On top of that because it was so big - it would have a tendency to come on, cool the space off very quickly then cycle off.
Because of that you could have more humidity and be less comfortable.
Old 6/20/06, 7:46 PM
Very short cycles in fact, you should have seen the water coming out of the condensate pan drain hose, a very steady stream. I could see the "A" coils and that were sweating badly, water just dripping off of them.
Old 6/21/06, 12:45 AM
The longer it runs the more humidity removed OR vice versa.
Old 6/21/06, 7:23 AM
Russel Ray's Avatar
Coleman is a major manufacturer, and York is a major distributor of the Coleman brand.
www.colemanac.com
They either specialize in mobile/manufactured homes, or they have a really nice contract with the manufacturers of such homes.
They seem to be to mobile/manufactured homes what In-Sink-Erator is to disposals.
In fact, I don't think I've ever seen anything other than a Coleman (or York) in the mobile/manufactured homes around here.
New Geo unit neat system cbottger Inspecting HVAC Systems 14 4/14/08 2:48 PM
Illinois: Carbon Monoxide Alarm Detector Act rcramer Legislation, Licensing & Legal Issues for Inspectors 2 2/9/07 7:52 AM
Help with unit size rcarter Inspecting HVAC Systems 4 2/1/07 4:55 PM
