Old 6/26/07, 7:38 PM
jlybolt jlybolt is offline
Please Note: jlybolt is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Need clearification of cleareance in front of evap coil
Ok - help me out with this . I have attic unit with appropiate platform for working cleareance in front of blower and furnace compartment. my concern is that the coil for the airconditioner does not have a platform in front of it and faces towards the rear or the attic. see picture. Would this not require the same platform in front of it for appropiate working cleareance. Any help would be appreciated.
Picture shows evaporator coil access facing rear of attic. Notice the condensation lines.
Old 6/26/07, 7:45 PM
Michael W. Gault's Avatar
Michael W. Gault Michael W. Gault is offline
Default Re: Need clearification of cleareance in front of evap coil
If the coil can't be removed if it needs to be replaced (or cleaned during a periodic service) call it out.
I call them out in my reports all the time when they are completely drywalled in under the home and the only access to the side without the evap coil cover...
Just doing your job...
- Mike
Michael W. Gault, SC RBI 1728
A to Z Home Inspections
Charleston, Dorchester & Berkeley Counties in S.C.
NACHI05040682
www.atozinspector.com
(843) 442-9755
Charleston Home Inspector
Old 6/27/07, 7:24 AM
Was there an aux pan installed?
1st Inspection Services
Bruce M. Graham III
Gainesville, FL 32608
352 871 8989
NACHI05091592
ICC 5268478
www.1stinspectionsfl.com
www.bungalowstomansions.com
Old 6/27/07, 8:32 AM
yes, there was an auxillary pan. Just concerned becuase of servicing
Old 6/27/07, 10:44 AM
Emmanuel J. Scanlan Emmanuel J. Scanlan is offline
2003 IRC:
M1305.1.3 Appliances in attics.
Attics containing appliances requiring access shall be provided with an opening and a clear and unobstructed passageway large enough to allow removal of the largest appliance, but not less than 30 inches (762 mm) high and 22 inches (559 mm) wide and not more than 20 feet (6096 mm) in length when measured along the centerline of the passageway from the opening to the appliance. The passageway shall have continuous solid flooring in accordance with Chapter 5 not less than 24 inches (610 mm) wide. A level service space at least 30 inches (762 mm) deep and 30 inches (762 mm) wide shall be present along all sides of the appliance where access is required. The clear access opening dimensions shall be a minimum of 20 inches by 30 inches (508 mm by 762 mm), where such dimensions are large enough to allow removal of the largest appliance.
Are those condensate pipes on the rear of the unit (white PVC) I can not easily tell from the picture?
Knowledge is power, but sharing knowledge brings peace!
http://www.psinspection.com
TREC License# 7593
Professional Real Estate Inspections for the counties of Collin, Rockwall, Hunt, Dallas, Tarrant, Kaufman and all surrounding areas. If you want the the best you will find it with PS Inspection & Property Services LLC!
Old 6/27/07, 10:47 AM
They are and the access cover is also. Builder says that theres nothing they can do about it. I told thme there was. Told them inadequate and improper working cleareance in front of access side of evaporator coil.
Old 6/27/07, 10:48 AM
deleted
Old 6/27/07, 11:31 AM
How is the condensate draining from that drain line??
As for the builder you have done your job and the client now needs to make a decision whether to pursue it or not. Since this appears to be new construction I would hope the client pursues it since they now know about it. If they fail to handle it now, before closing, it is no doubt going to be harder later after closing and trying to deal with TRCC.
TREC License# 7593
Old 6/27/07, 11:33 AM
condensate is properly installed and runs to a sink trap.
Old 6/27/07, 11:34 AM
there was excessive condensation on bottom of unit when I reached under and felt the bottom side. Im thinking fan speed might be the culprit. Small drops of Condensation from the bottom of the unit was starting to drip into the secondary pan.
Mismatched dead front ghawley Electrical Inspections 5 2/10/07 9:56 PM
Explaining MultiWire Circuits- For Fun :) pabernathy Electrical Inspections 38 11/8/06 6:04 PM
