Does the ac condensate line have to be rigid pipe where it attaches to the tail pipe of a vanity. Need code reference
| Need a home inspection in Mississippi? Check out InterNACHI's listing of Mississippi certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
M1411.3.2 Drain pipe materials and sizes. Components of the condensate disposal system shall be cast iron, galvanized steel, copper, polybutylene, polyethylene, ABS, CPVC or PVC pipe or tubing. All components shall be selected for the pressure and temperature rating of the installation. Condensate waste and drain line size shall be not less than 3/4-inch (91mm) internal diameter and shall not decrease in size from the drain pan connection to the place of condensate disposal.Where the drain pipes from more than one unit are manifolded together for condensate drainage, the pipe or tubing shall be sized in accordance with an approved method. All horizontal sections of drain piping shall be installed in uniform alignment at a uniform slope.
Jeff Gatt is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would think you need to look at the bigger picture as to where the condensate drain is connected. Code requires that the condensate be connected to the building drain though an air gap connection and NOT physical to the drain. If the drain system backs up the there is potential that it can back up into the evap coil |
(e.g. IRC M1411.3 Condensate Disposal ... http://publicecodes.citation.com/ico...011_par002.htm) Acceptable places for disposal include roof gutters, discharge at grade (preferably not draining across a walking surface), and fixture waste connectors before the trap (e.g. sink tailpiece before the trap). For the last option the AC unit just needs to be above the sink (attic installations) or connected through a condensate pump (basement installations) to physically connect the condensate lines to the waste drain. Family mechanical business has been doing it that way for quite some time, including new construction with some very strict/picky building inspectors. JMO & 2-Nickels ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... |
I wouldn't worry too much about the sink backing up into the evaporator coil up in the attic Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX |
I wouldn't worry too much about the sink backing up into the evaporator coil up in the attic Chuck Evans (TREC #7657) Level III Infraspection Institute Certified Infrared Thermographer (#8402) HomeCert Houston Home Inspections & Thermal Inspections Find us on Facebook Houston Thermal Inspections & Infrared Imaging Find us on Facebook Houston Home Inspector Houston, TX Last edited by cevans; 6/26/11 at 6:35 PM.. |
Flexible piping used to connect the condensate drain to a sink tailpiece should be polyethylene or polyvinylchloride tubing (usually milky white or clear) ... see Jeff's post.
Using flexible poly tubing for connecting to a sink tailpiece is the preferred method for many installers, because it's only a matter of time before gunk, hair, etc. clog that tailpiece wye fitting and it needs to be taken apart to properly clean. It looks similar to a dishwasher drain hose connection. JMO & 2-Nickels ... Robert O'Connor, PE Consulting Engineer & Inspector LIU CW Post Adjunct Professor NACHI Education Committee www.reporthost.com/-rjo I am absolutely amazed sometimes by how much thought goes into doing things wrong ... Last edited by roconnor; 6/27/11 at 11:42 PM.. |
| What to do with a blocked condensate drain line | jhugenroth | Inspecting HVAC Systems | 5 | 1/19/11 6:51 PM |
| Condensate Drainage | jevans | Inspecting HVAC Systems | 28 | 11/27/10 2:55 PM |
| TPRV line and condensate line marriage | ccarrington | Plumbing Inspections | 3 | 4/29/06 7:59 AM |
