bdoles2 is a non-member guest and is in no way affiliated with InterNACHI or its members.
Shouldn't there be a trap on this setup, before the vertical vent. This set up is blowing conditioned air out the vent.
From what I see in the picture, yes a trap should be installed. As far as they system blowing conditioned air into the space, I don't see how that would be possible. The condensate pan is below the evaporator coils which are below the blower. I could see the possibility of it sucking air through the blowout in the picture, but not blowing air out. If it really is blowing air out, I would check the rotation of of the blower motor and it's orientation.
Just read another thread and completely forgot about blow through set-ups. I don't run across any where I'm at because most HVAC contractors install draw through systems from what I see around here. If it is a blow through system, then yes you definately need a trap and there neds to be a cap on that blow-out fitting. Scott Gilligan 215-888-4943 Infraspection Institute Level III Certified Thermographer Philadelphia Mold Inspections Philadelphia Home Inspections Philadelphia Commercial Inspections Philadelphia Licensed Home Inspector Pennsylvania - New Jersey - Delaware Infrared Thermal Imaging Inspections President The Greater Philadelphia Chapter of InterNACHI http://pa.nachi.org/greaterphiladelphia Vice President & Webmaster National Association of Commercial Building Inspectors and Thermographers Last edited by sgilligan1; 8/1/07 at 7:20 PM.. |
I wish furnace and heat pump manufacturers put installation documents on the web like other appliances do (water heater,etc...). You know, something to refer to.... |
This pages may help.
They used to be on the Trane site, but have disappeared. I retrieved them form the Wayback Machine Net Archives, and combined them into a single document: |
| HVAC in unvented, spray foam insulated attic? | lfreeze | Inspecting HVAC Systems | 17 | 6/20/07 10:58 AM |
| Room size requirement for HVAC supply | kweiss | Inspecting HVAC Systems | 3 | 6/9/07 7:58 PM |
| Access to Electrical Panel in Ontario by HVAC Contractors | Nalliah Thayabharan | Canadian Inspectors | 8 | 5/21/07 4:01 PM |
| Condemned Furnaces Spark Safety Issues | Gary Reecher | Inspecting HVAC Systems | 7 | 3/8/07 9:17 PM |
