Todays inspection was a duplex with 2 boilers and 2 hot water tanks. All natuaral gas. Each water heater exhust vent was connected to the vent for the boiler and all 4 were vented into a single flue chimney with no liner.
House was built in the late 1800s. Note the pressure relif valve. Last edited by prussell; 11/27/07 at 9:08 PM.. |
In the last picture this is a vent for the boiler, notice the deterioration in the pipe, directly opposite from these hole's is where the vent for the water heater is connected.
apolillo is a non-member guest and is in no way affiliated with InterNACHI or its members.
I would definitely write up the unlined chimney and suggest a level 2 inspection and calculations on the proper sizing for the number of vents using it.
Anatol |
Thanks Anatol; does anyone have the code for venting multiple gas units?
apfaff is a non-member guest and is in no way affiliated with InterNACHI or its members.
High potential for back-drafting, refer it to the HVAC technician.
I would also recommend having HVAC tech calculate combustion air needs. That many appliances burn a lot of air. From those pictures I bet they will be doing some repairs! |
| Todays Crawl space | bkelly1 | Miscellaneous Discussion for Inspectors | 16 | 3/3/06 5:16 PM |
