This picture was taken in a closet where the air hander was. You can see the bottom of the unit and the white pipe that runs over to the drain is the condensate. I wrote in the report and explained to the buyer that when this trap is dry in the winter, the opportunity exists for sewer gas to be sucked back into the home and dispersed via the HVAC system. The seller agreed to fix it and the HVAC tech says that there is no problem with it and it is common and to code. I explained again to the buyer my concerns and asked her to get this HVAC tech to write her a letter documenting that the system was safe, which I know will not happen.
Am i incorrect about what this picture represents? Edit: This is the letter the HVAC guy wrote, I am scratching my head To whom it Concerns, On July 24th,2O11 I performed an HVAC inspection on a property located at xxx., Virginia Beach, VA. The area of concern was due to a home inspection stipulating the HVAC condensate drain being tied into the sewage line and possibility of sewage gases escaping into the house via the HVAC system. Upon my inspection and the assistance of the home seller and a neighbor, the systems in these townhomes were designed in all units in this manner. There was no evidence present to suggest sewer gases have been escaping into the HVAC system for this townhouse. By all accounts the system is safe for use and occupant. Inspecting Norfolk and Hampton Roads www.procraftinspections.com Energy Audits in Norfolk www.procraftgreen.com Last edited by bbrinke; 8/19/11 at 8:12 PM.. |
| Need a home inspection in Maryland? Check out InterNACHI's listing of Maryland certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
If the HVAC tech signed his letter, you're off the hook. If anything should happen, like maybe, gases or foul odors do enter the house, the HVAC will be obligated to correct the system at his own expense. If nothing happens...
The HVAC tech that signed the letter is an idiot and has no clue what he is talking about. He signed the letter let him be responsible. Unless the furnace is a 90% furnace and produces condensate in the heat mode there will be sewer gas entering the air stream of the furnace as soon as the condensate evaporates from the trap. In Oklahoma that would be about the middle of November
Good catch Brad.
I have never seen a design like that with a drain inside plus I hate when they design returns that way to begin with.(the dirt sticks) Guess they have something against sheet metal. www.chicagopropertyinspection.com www.elliotthomeinspection.com www.chicagolandhomeinspection.com www.homeandcondoinspector.com www.homeandcondoinspection.com http://www.homeinspectorpro.com/ (Report Software) Bob Elliott http://www.chicagolandhomeinspector.com/ Last edited by belliott; 8/20/11 at 4:20 AM.. |
I find it pretty interesting or strange the HVAC tech. stated:
“Upon my inspection and the assistance of the home seller and a neighbor, the systems in these townhomes were designed in all units in this manner”. I don’t think I’ve ever seen someone use a home seller and neighbor as supporting credentials or for justification. As you stated in your report, it may become an issue. What else can you do? |
Rather than fix it (which is their job), they want to discredit the home inspector for making the call. IF YOUR INSPECTOR IS NOT USING THERMAL IMAGING, YOU'RE NOT GETTING THE WHOLE PICTURE ® Jeff PopeJPI Home Inspection Service Santa Clarita CA (661) 212-0738 Santa Clarita Home Inspection http://www.MyInspector.net |
We recommend "licensed contractors" to repair or replace the material defects that we find while we often forget to remind ourselves that "licensed contractors" were often the mental midgets who created the material defect that we are reporting on. When the parties to the sale consult with these "licensed contractors" who, as this one, admits to condoning inferior building practices on a regular basis --- we share the blame for recommending the consultation in the first place, IMO. I think our reports should be more forceful in communicating the simple fact that "XXX is wrong and needs to be fixed. Client is advised to find a competent contractor who can recognize the defect and is qualified and able to implement corrective measures". When the client calls to tell you that the HVAC Tech they talked to says "It's okay", we should simply suggest they keep looking until they can find a competent HVAC Tech that can recognize the inefficient and harmful manner in which the observed conditions can affect the indoor air environment of the home - and leave it at that. James H. Bushart Professional Building Analyst, BPI Missouri, Kansas and Arkansas 314-803-2167 Last edited by jbushart; 8/20/11 at 12:05 PM.. |
I think you're on to something there Jim. I think I'm going to implement a variation of this wording into my recommendations.
| SoPRFI Basis of opinion | jcahill | Texas/TPREIA Inspectors | 5 | 6/1/10 9:16 PM |
| Attorney General's Opinion to TREC Request | mboyett | Texas/TPREIA Inspectors | 11 | 12/5/09 11:44 PM |
| According to the latest opinion polls... | jwilliams4 | Miscellaneous Discussion for Inspectors | 0 | 10/18/08 9:50 PM |
| Texas Atty. General Renders Opinion about Liability Insurance | bthompson1 | Legislation, Licensing & Legal Issues for Inspectors | 45 | 12/20/07 11:57 PM |
