I'll try to get a photo up later when my internet cooperates. I was looking at a 43 year old furnace which I am at least recommending some routine maintenance and a complete evaluation on for several reasons. It's a low efficiency, open draft hood, rusty antique. There were several water lines/stains from moisture leaking out of the A/C pan and running down around the furnace.
One set of rusty water stains was at the back of one of the burners inside the heat exchanger. My question to the furnace gurus is, would these stains be considered confirmation of cracks in the heat exchanger since water made it through to the interior of the burn chamber? Cameron Anderson Bachelor of Architecture, U of I, Urbana IL Illinois Licensed Inspector www.aaintegrityhomeinspection.com |
| Need a home inspection in Rhode Island? Check out InterNACHI's listing of Rhode Island certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
Hello? Anyone?
The only response you will probably get is Mr. Jonas yelling at you to add a photo.
Juan Jimenez
A House on a Rock Home Inspections LLC God. Family. Home. 571-208-3286 http://ahouseonarock.com Richmond, VA Home Inspector Richmond, VA Radon Tests Recommend US! http://www.facebook.com/RichmondHomeInspector |
When you create heat you create moisture. If the burners are set incorrectly and you are getting a cooler flame condensation can accumulate causing the staining. Not sure about the cracked heat exchanger though. I learned this from a heating tech about a month ago: He lets the furnace run for about ten minutes and the heat exchangers are red hot. He turns the burners to pilot and lets the fan run. He lites a piece of newspaper and puts it out so he has smoke. Run it along the burners and look for signs of the smoke coming back instead of going into the chamber. I would not use this as difinitive but another clue there is an issue. I also use a carbon monoxide detector and a mirror. I will never ever ever tell them yes or no as it should be confirmed but I will say it is suspected.
Greg Mathias, CCHI Journeyman Carpenter Level I Thermographer Global Property Inspections Lloydminster, AB. Canada (780)205-9912 |
Based on my limited information from your post, I would recommend "evaluation by a licensed HVAC contractor to evaluate, repair or replace the heating system. Due to age and normal wear and tear and projected life expectancy, the unit may need to be replaced at any time." and state any visible rust, and if/how the unit operated. Nuff said.
Personally I would not comment on the heat exchanger at all unless it is clearly evident. Touchy subject lately. Have you seen Ben's video on Heat Exchangers? I learned a ton. (Thanks Ben) http://www.nachi.tv/hvac/crack-heat-exchanger.htm |
Bill Boerner STL Home Inspection Services LLCServing St. Louis/Surrounding (314) 805-2137 office@stlhomeinspector.com http://www.stlhomeinspector.com Residential, Commercial, Radon, Termite, Lateral Sewer Scopes |
Actually, I see that my subject line was poorly chosen. This is not a request for what I should put in my report or tell my client, this unit is so old a cracked heat exchanger is a foregone conclusion whether I would say it or not. I just wanted to see what the opinions of inspectors and HVAC guys would be if they came across this. Cracked or not cracked? Could it be another viable piece of evidence? In the photo, I think it's pretty clear the water did not form as a product of combustion. It traveled down only one or two spots and stayed wet for a while allowing it to rust in the pattern it leaked. The moisture then leaked out the front of the exchanger(2nd photo). There were also stains all around the outside of the unit which came from the A/C. My assumption would be the seams at the top of the exchanger would be watertight, but perhaps they could allow a condensate leak to trickle down. Cameron Anderson Bachelor of Architecture, U of I, Urbana IL Illinois Licensed Inspector www.aaintegrityhomeinspection.com |
Was the evap coil before the heat exchanger? David eloquently explained that when its before the exchanger it cause excessive moisture, rust, and cracking of the heat exchanger.
Juan Jimenez
You Cannot make a silk purse from a sows ear. The furnace has exceeded an average life expectancy for the type of equipment Defer to the contractor and move on its to old to even be concerned
- Design life expectancy of the HVAC is 15 - 20 years. - Recommend annual service and evaluations on all HVAC equipment to maintain. Recommend service of the HVAC at this time if annual service has not been performed. - Service records are not visible or apparent at time of Inspection. Recommend obtaining service records from the homeowner. - Due to the age of the HVAC equipment, replacement needs should be anticipated and estimated.at this time. Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 10/13/12 at 11:56 PM.. |
Juan, no the A/C coil was above and after the HE. Cameron Anderson Bachelor of Architecture, U of I, Urbana IL Illinois Licensed Inspector www.aaintegrityhomeinspection.com |
Cam I understand what you mean. You know what to report but you want to actually understand how that happened. I am not sure why people keep commenting with how to report it. I gave you my only guess.
Juan Jimenez
and........... If you do not recommend the need for replacement..... Guess who the HVAC Contractor will be suggesting should be responsible for PAYMENT of REPLACEMENT...... ........................... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member Last edited by jhagarty; 10/13/12 at 11:46 PM.. |
The difference between discussion of
Business and... Reality..... Joseph P. Hagarty joseph.hagarty@comcast.net Main Line Inspections, Inc. Phone: 610-399-3675 Email: MainLineHI@comcast.net http://pa.nachi.org/mainlinepa/about.html http://www.householdinspector.com National President / NACHI (2003-2004) NACHI Education Committee Member |
What in the world are you talking about? No one came close to suggesting that he not recommend replacement.
Juan Jimenez
| Advice for Ride-Alongs | ppendley | Inspection Education & Training | 14 | 10/25/11 1:08 PM |
| Commercial Infrared Inspections Training & Advice Please? | bclark3 | Thermal Imaging, Infrared Cameras & Energy Audits | 13 | 9/24/10 12:31 PM |
