Old 7/22/07, 12:04 PM
Al G. Liminator Al G. Liminator is offline
Please Note: Al G. Liminator is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default New product I would love everyone's opinion on
Good Morning folks. I have a new product that will soon be on the market that I would love everyone's opinion on. It is an in-line P-trap Chlorinator. It's called the AL-G-Liminator, hence the user name. It installs in the condensate drain line of an A/C. It forces the condensate over a chlorine tablet that treats the water and kills cold water algae down stream. It also is a P-trap and will replace the existing trap or it will keep it clean. Any opinions will be very appreciated.
Old 7/22/07, 12:08 PM
Harold E. Miller's Avatar
Harold E. Miller Harold E. Miller is offline
Default Re: New product I would love everyone's opinion on
What is the benefit of treating the A/C condensate discharge for algae?
Old 7/22/07, 12:23 PM
This algae or slime will stop the p-trap and piping down stream of "liminator from plugging.
Old 7/22/07, 12:26 PM
Doug Edwards's Avatar
I'm pretty sure its been done. I used to have some blue tablets you dropped into the drain pan for the exact same purpose. I know there are algaecide pads that do the same thing, but if it works and you can make some money with it I say good on ya and wish you success.
Old 7/22/07, 12:30 PM
The chlorine would have an adverse affect on the decomposition of the septic tank contents by killing the bacteria, if so drained.
Larry Kage, CMI
231 929 3525
Old 7/22/07, 12:35 PM
Thank You for the encourgament. I have also seen these blue pills for the drain pans. The hold-back on these is acess to the pan. You have to cut a hole in units to get to the pan. Unless you are talking about the secondary drain pan. I hope that with the use of the 'liminator the secondary drain pan will never see water. Also I'm not sure how long these pills last. One chlorine tablet will keep the drain line and p'trap clean for at least the whole cooling season even in south.
Old 7/22/07, 12:37 PM
In my opinion the chlorine coming off the tablet will be only a fraction of the chlorine from bleach used in washing clothes.
Old 7/22/07, 12:38 PM
Poster is talking about the p-trap on an HVAC condensate drain line which should never be incorporated into a septic tank. NO one wants to accidentally draw sewer gases into the AC system and distribute it throughout the house. I will say I have actually found this set up (homeowner installed) and called it out.
Old 7/22/07, 12:41 PM
David A. Andersen's Avatar
You need to market test it at a local HVAC supplier.
We often tried stuff out like this. Some fly and some say good-by!
I don't think HI's will have much input for you. HAVC is the great unknown.
Condensate blockage is something that "will" occur in time, not "might"!
Anything that makes homeowner service maintenance has a plus, but the HVAC contractors make money "servicing" and repairing this equipment, how will it help them?
Traps that can not be cleared must be cut out. If your product is an easy replacement part that facilitates replacement of the trap it may have it's advantages.
Adding two unions so the trap can be disassembled without cutting and gluing is almost cost prohibitive in many cases. The home owner doesn't do the maintenance so they don't want to pay of the upgrade. What cost are you proposing?
Old 7/22/07, 12:55 PM
Blockage is something that brought this product to the market. My personal drain plugs at least twice a year. As far as the advantages to the service reps, someone will have to install and maintain this for a certain percentage of consumers but the average do-it-yourselfer will save their hard-earned money for other things. The only service this needs after installation will be tablets once per year. Everyone should have an expert check their unit out at the start of each cooling season.The tablet will be added at that time by the rep. We priced this unit under the average service call for plumber or HVAC technician.
Old 7/22/07, 2:17 PM
Charley L. Bottger's Avatar
Sounds like a good idea why don't you send me one as a test Beta for I year and I will let you know If I like it
</IMG>
freedomexpressinspections.com
freedomexpress495@att.net
NACHI Member
State License # 130
Old 7/22/07, 2:27 PM
I like that. It never hurts to ask. Like I said this is a new product. It will be about 6 weeks before it's molded. The web site will be up and running in about 2-3 weeks. Keep checking WWW.AL-G-LIMINATOR.COM. Patent info went off about 4 weeks ago. Send me an e'mail. A freebee is not out of the question.
Brussellhome@cox.net
Old 7/22/07, 6:18 PM
Send one to Charlie, I have three package units so they won't be useful there.
Old 7/22/07, 6:27 PM
Roy D. Cooke, Sr's Avatar
Welcome to the NACHI site.
Usually when I want help from some one I introduce myself to them.
You are wanting our thoughts with out knowing who you are or where you live .
Now you know my feelings, I wish you luck and it is great to see you come to many great Inspectors for help.
Personally it could work but will it sell I do not think so, but if by chance you have a winner starting out slow the competition will get a copy and if it is good they will flood the market before you even find a distributor
. Cookie
Old 7/22/07, 7:19 PM
klott's Avatar
klott klott is offline
Thumbs up Re: New product I would love everyone's opinion on
Mr. Liminator, great idea, I have a big problem wiih my drain, send me a freebee, if it works, I will sell them for you, I have a few connections, I might be able to get you in the door. I have been working on something similar for the human body, I will call it; I.P. Freely
CPSC Product Safety Report- Latest pabernathy Electrical Inspections 0 8/30/07 7:14 PM
A little help from our old friends. tallen General Inspection Discussion 25 8/7/07 9:42 PM
Recall Notice - CPSC Notice pabernathy Electrical Inspections 1 1/25/07 7:34 PM
