What damage can be done to a heat pump system by not using filters. I know the returns can collect dust, but how about damage to the air handler?
| Need a home inspection in Vermont? Check out InterNACHI's listing of Vermont certified home inspectors. Or, find a home inspector anywhere in the world with our inspection search engine. |
The dirt will build on on the blower wheel unevenly cause a bushing or bearing to fail prematurely.
Also clogging up the A/C coil causing ice to form and freeeze up.
Jim, not sure I follow the part about ice on the AC coils? Do you mean at the outside compressor? This system was partailly iced up but not sure how the dust inside impacts the outside componets. Sorry for my ignorance.
mivie is a non-member guest and is in no way affiliated with InterNACHI or its members.
I think he is talking about the coils at the air handler. This is a costly fix.
Blower "sux" from the returns, not "blows". Jeffrey R. Jonas Critical Eye Property Inspections JRJ Consultants Owatonna, Minnesota Chapter President InterNachi Awards Portal: http://co.nachi.org/inachiawards/
Scott
Without enough air flow over the indoor coil in cooling mode on a heat pump, the system pressures and temperatures will drop below 32 degrees and cause frost and ice to form on the indoor coil and the suction line and compressor, more importantly cause the superheat to drop to a point that the compressor may try to slug lquid refrigerant. Remember your high school physics, you cannot compress a liquid. This may be TMI, just remember that lack of indoor air flow is important and is a classic explanation of what you are seeing. As for Jeffery saying that return has nothing to do with how a blower blows, think about it if the return air is blocked tell me how the blower gets air to blow? |
| New picture...Heater with two filters | dnasser | Inspecting HVAC Systems | 3 | 12/10/09 12:36 AM |
| Two filters in Heater. Question | dnasser | Inspecting HVAC Systems | 1 | 12/9/09 10:09 PM |
| Zefon Mold testing units and filters For sale | Joe Goodwin | Ancillary Inspection Services & Additional Topics | 2 | 10/10/09 1:41 AM |
| MERV Efficiency Rating for Filters | Brian A. MacNeish | Inspecting HVAC Systems | 21 | 1/6/09 4:27 PM |
