There was no hearth on this fireplace with gas logs. I have not been able to find any manufacturers recommendations. It would seem like there should be some hearth. Is there some type of common recommendation for this or is it up to the manufacturer?
Boy my eyes are not gettin' it tonight.
Is that glass enclosed? Some manufacturer's of sealed units allow carpet right up to the wall. Check the install instructions. InterNachi Awards Portal: http://co.nachi.org/inachiawards/ ____________________________________________ "An Education, not just an Inspection" Larry Kage, CMI Lake Ann (Traverse City), Michigan 49650 231 929 3525 Professional Inspector serving the Traverse City, Michigan area and beyond.
I dont believe a GAS LOG setup needs a harth....however if it is set into a normal fireplace opening in which the logs could be removed.....and wood burned within the area....then harth would be required.
But most pre-built units wont have a harth Paul W. Abernathy |
whandley is a non-member guest and is in no way affiliated with InterNACHI or its members.
For the record, I believe the hearth is actually the bottom of the fire box that the subject gas logs are resting on. The wood flooring covered area off the fire box and hearth would be called the hearth extension, no?
Having said that, I also believe if the unit is fixed glass sealed, no non-combustible hearth extension would be required. Merry Christmas! |
I haven't found a glass window unit that requires a hearth extension (as Will said). I can't tell from the picture whether or not that fireplace has a glass window. It looks like there is a little pull chain at the left, which leads me to believe that there used to be a chain screen and glass doors, indicating that it probably needs a hearth extension.
wforsyth is a non-member guest and is in no way affiliated with InterNACHI or its members.
Most importantly, though, it needs a hearth extension if the manufacturer says it does, or if the local codes say it does. And if both of those are silent, it's kind of like carbon monoxide detectors ( NACHI 2005 U.S. Member of the Year
In your typical "what if" world Russel, you can justify anything.
Just because in the "what if" instances you named, it may be safer, does not mean it is something that needs to be written up, or should be. |
I did say that the manufacturer's installation instructions and/or local codes will govern, and that if they are silent, safer is better. To have you imply that safer might not be better is waaaaaaaaay beyond even you. What's with you tonight? Not enough red boxes? Anyway, my Interactive Report System seeks to educate my Clients. Education is knowledge, and knowledge is power. I like to empower my Clients through education. I think the whole basis of home inspections is "what if." To me, that's a big, big DUH! If we weren't looking for "what if" scenarios, the worst that can happen, there probably would be no need for home inspections, and, of course, no lawsuits against home inspectors for not finding those worst case scenarios or failing to educate one's Clients about those worst case scenarios. Educate, educate, educate. NACHI 2005 U.S. Member of the Year
| Gas Logs........ | pabernathy | Inspecting HVAC Systems | 11 | 12/25/06 8:58 PM |
| NG vs LP gas logs? | bmargiotti | Inspecting HVAC Systems | 3 | 10/31/06 12:10 AM |
| Ventless Gas Logs | Skip Erwin | Inspecting HVAC Systems | 5 | 7/7/06 2:33 PM |
| Gas logs | dmacy | Inspecting HVAC Systems | 9 | 3/17/06 8:35 AM |
