Old 8/22/07, 2:02 PM
Alan Dow Alan Dow is offline
Please Note: Alan Dow is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default No high side
I work at an apartment complex that was built in the early to mid 1960's. My problem is that with this heatwave we have been having, all my compressors are siezing up, and none of the original units have a high side access port. without draining each unit and installing a valve, is there anyways to establish what my high side pressure is?
Old 8/22/07, 2:15 PM
rramsey rramsey is offline
Please Note: rramsey is a non-member guest and is in no way affiliated with InterNACHI or its members.
Default Re: No high side
Saddle valve can tap an existing line without losing all of charge
Good luck
Old 8/22/07, 2:47 PM
sparksnmore sparksnmore is offline
Please Note: sparksnmore is a non-member guest and is in no way affiliated with InterNACHI or its members.
I've used a lot of these solder on access valves
http://www.hvacr-tools.com/mm5/merch...ry_Code=VALVES
Keep on the Sunny Side... Always on the Sunny Side, Keep on the Sunny Side of Life jburkeson1 Miscellaneous Discussion for Inspectors 0 8/22/07 9:33 AM
ALCOA vinyl siding one side warping, why? Lynn Kelly General Inspection Discussion 4 5/23/07 4:32 PM
All Breakers on left side of bus mcotten Electrical Inspections 18 2/1/07 1:24 PM
