Inspected a condo today that had a Carrier air handler (electric heat) that had an open filter on the bottom of the unit with no return duct. Unit was in a closet with a louvered door. I assume the louvered door and closet were acting as the return. Anyone familiar with this setup?
| Find an InterNACHI certified Florida Home Inspector (and anywhere else in North America) |
Yes, if the furnace is in the center of the home and the supply registers are near the outer walls than it should work okay. This is the econo way of installing a furnace and definitely not the best way.
How old is the unit, with copper condensate line, or is the owner loaded?
1st Inspection Services Bruce M. Graham III Gainesville, FL 32608 352 871 8989 Florida Licensed Home Inspector #HI10 Radon Measurment Technician # R2279 NACHI05091592 ICC 5268478 www.1stinspectionsfl.com www.bungalowstomansions.com |
Took me a minute to figure because it through me for a loop not expecting the filter to be facing straight down. The A/C condenser was built in also ,with an wall vent to the outside of the unit. Is that what you found? |
| moving a return air duct for remodel | Julie Ream | Inspecting HVAC Systems | 1 | 1/30/09 2:00 PM |
| Critter in the return air duct... | swaskewicz | Inspecting HVAC Systems | 11 | 11/28/07 3:49 PM |
| furnace return air duct | vwood | Inspecting HVAC Systems | 5 | 6/19/07 1:18 PM |
| Reduced return air duct | mmorgan | Inspecting HVAC Systems | 4 | 6/6/07 7:39 PM |
